Results 1 to 10 of 35
Thread: A.C. Malfunction when on Auto
    Aug 2008
    Hi fellas, my AC is doing something strange when on Auto control. Normally I set the desired temp and let the system take care of the rest. At the last service they did not have the filter element in stock so the left it out and week later when I had time I dropped back in and they installed it. All was good! About a week after that It was a warm day (32c) got in the van and there was a strange noise coming from below the dash on passenger side., sounded like the fan. Then I could smell an electrical burning smell..... it only lasted for a few seconds but was there.
    Since then the AC system has been playing up when in Auto mode. It will start and run for a few minutes then the fan drops to nothing even though the display shows it on full speed. I switch it off for a few minutes and sometimes it works normally and other times it does not. Now here is the strangest part, if I just run it in full manual mode it works perfectly! If I switch it over to auto it some times works or it shuts down.
    I dropped into my mechanic , explained what was happening so he connected it up the VW diagnostic computer and scanned it. Sure enough there was an error code! It basically says climate control. He reset the fault and lets the computer run another full test and its all clear. He then does the same again with the engine running and the AC on.... works perfectly again in auto mode.
    I set of again and all was good. Stopped at the hardware store, came out 1 hour later and it would not work. Shut it of, let it sit for a few minute as I drove with the windows down. Then started in manual mode...and it worked again. Only other thing is it seems to happen on warm/hot days.....when you need AC the most.
    So..... has anyone else had something like this happen? Any suggestions on what to look for or check? I get the feeling its a sensor the controls the Auto mode and thats why the AC still works in manual.
    2005 T5 Multivan.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Canberra
    From the symptoms you have described I would be much more suspicious of the mechanism that adjusts the fan speed when in auto mode - presumably it is some kind of small motor/solenoid that alters which resistor the power for the fan goes through. It sounds like the fan speed control itself is fine (works OK in manual mode).
    Caveat - my T5 has manual HVAC, so I have no direct experience of the automatic T5 ones. I can't remember reading of this particular problem before, so it seems it is uncommon.
    2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
    Sep 2008
    Gold Coast
    32 degrees C is warm?
    Sorry, couldn't resist
    Aug 2008
    Quote Originally Posted by Deeceer View Post
    Yeah yeah everything in Queensland is bigger and better LOL ! It was 42 here on Sunday....I think thats hot but where does that fit into the QLD'er scale? You blokes probably have your cardigans on the heater on full eh LOL!
    Turns out the fan/blower unit is buggered.....only $620 for the part plus fitting! Hopefully it turns up Wednesday?
    Jun 2007
    Melb.
    Quote Originally Posted by Ivo View Post
    The extended factory warranty offer I saw on the counter of the service dept. looks more attractive now that i think about it....3yr/60,000km approx. $1,900
    Aug 2008
    More good news None in stock Australia wide....has to come from Germany....maybe 2 weeks!
    Canberra
    If you are paying for that out of your own pocket (ie not a warranty job) I suggest you keep the old one and see if it can be fixed cheaply - that way you can either keep it as a spare or flog it off to save some other poor sod some $$$ and also recoup some of your costs.
    Often there is only one small component that has failed, but these days the manufacturer only supplies a complete unit (and strangely enough, the complete unit always seems to cost WAY more than the component).
    As an eg some Golfs (and similar VAG vehicles) have an ABS unit that frequently fails. VAG charge approx $3,000 for a new unit, but there is a mob in the UK that replaces the duff sensor that is usually the actual fault, reconditions the whole thing and sells the refurbed unit for under $200 (IIRC).
    Aug 2008
    The mechanic has pulled it apart and it needs new brushes. None in stock down here but they have ordered in from Brisbane and should be here Friday!
