Results 1 to 10 of 15
Thread: T5 4Motion lift and tyres...Help??
    Apr 2009
    Canberra
    Hi all,
    time is coming to replace tyres on Lola the Tranny, she is also sagging a bit in the rear due to constant weight so I am after a bit of a lift and maybe one size up (profile) on the tyres.
    Any experience out there with these mods??
    BTW she is an ex Ambo, and is running Nokian tyres which have been GREAT, I have put 35K km on them and see 15K more before they would be dangerous (ie obviously bookable or insurance risk!)
    Pascoe Vale, Vic
    hey there,
    best advice I can give is either talk to pedders about H/D springs, they do a good job. or if you're really serious, look here Home - www.seikel.de
    cheers
    Daily Car: Random BMWs | My Toy: R33 Skyline GT-R | GF's Car: 1954 Beetle 'Oval' | Our (Her) Car: Alfa Romeo MiTo Sport
    Adelaide hills, SA
    I Carry a lot of loads too and recently replaced rear springs (king Springs) and heavy duty shockers from Pedders. I'm happy with the solution. Rear looks now like there is no load at the back at all, handing is not affected. More in this post. http://www.vwwatercooled.org.au/f136...tml#post439571
    The van has 17" steel wheels with 235/55/17 tyres.
    Dec 2008
    Northern Suburbs
    bilstien do a heavy duty upgrade kit which is used in the t5 ambulances.
    Jun 2007
    Melb.
    I'll second Flyingfridge & Transporter here. In my previous T4 I used the Polyair air bags and now with the T5 have the Pedders Kings'. The inflatable method means you can adjust your height while the Kings under no load give a far more obvious tail up profile. This is a cosmetic sacrifice I'm more then happy to make as when I load over 800kg purely in the rear third area by forklift I have a small taildown look, say 2" below level, but the rear mudflap never strike the ground over bumps and there is no "floaty feeling" which would happen with the polyairs. Plus springs won't ever run the chance of leaking.
    As to tyres, I actually got 87,000km out of the original Michelin Agilis 51 16' tyres however I went to Pirelli Chrono. I could have probably gone another 2000 before legally pushing it, but with winter here and rain finally in Vic it would be a risk not worth taking.. They're not cheap however in 215/65/16 there are no Hankook Dynapro's with the correct load rating.
    Apr 2009
    Canberra
    Thanks for the replies, would love to go Seikel thanks flying fridge but the cost is umm........ way outa there to be polite!!
    Had thought about bags but the van is loaded basically all the time and rides well with springs , ie not floaty, and am keen to keep it that way.
    So it looks like Pedders will get a visit, and I will check what I have , maybe some Bilstiens reside in the Wheel wells already, if a little worn, Lola has 112K km, and she does carry a load, along some pretty rough trails at that!!
    I will have to see what height I get and do tyres from there, the extra clearance would be nice, as I said she sees a trail or two.
    Thanks again to all
    Mar 2008
    Tyre Search, Beaurepaires, Australia
    The Good Year Cargos are plentiful and are available in many sizes including 215/65R16C 106T
    Regards,
    Scott
    Adelaide hills, SA
    Quote Originally Posted by tron View Post
    Thanks again to all
    My T5 drives better with raised springs and H/D shocks than with original shocks and springs. The original shocker on left side was replaced (under warranty at 35,000km approx.).
    And most likely you have Monroe shockers (made in Belgium) at the back at least that was in my T5.
    Apr 2009
    Canberra
    Ta again for the replies,
    Frantic, I had a look, and unfortunately I missed on the Bilstiens so there will be no rebuilds
    Silver 'velle, I dont really know how the Cargo's would go in mud/wet grass, these being the most common conditions where the 4 Motion system has been a blessing for me so far. I just love it when my mates Hiace gets nowhere near the job and Lola (my pet Tranny) dosen't even seem to slip a wheel!!!!
    Transporter Ta for linking me to the how to do post, VERY informative and helpful, I just wish my car was that clean underneath!
    Now for some Quotes and spending before Tax time, oops that cutting it fine!!
    Jun 2006
    with the dust and flies in western Victoria
    Tron..the Goodyear Cargo G26's are fine on the mud & grass. My set on the T4 took us around the country some time back. NO punctures. Handled commuting on the Darling River Run even on the rare damp-ish days...I did have a memorable hour on the blacksoil south of Bourke after 15mm but still made it home without getting stuck. The dirt roads shortened their life considerably but they do that to all tyres...
    Beware the Cargo Marathon's however....fortunately they are only available in one 16" size.
