Results 11 to 20 of 24
Thread: Buy your own can bus scanner?
    Apr 2013
    Upper Gully VIC
    Thanks for taking the time to explain that. For me I think the ODBII will be enough for now. I just want to get some idea of what a problem might be before I get the mechanic involved. My current/previous mechanic treated me as a mushroom and just wouldn't tell me what the code number was. At this stage it's unlikely I'll attempt any repairs myself (my history with fixing cars is not an illustrious one . I'm hoping for happier times with my soon to be new VW specialist mechanic anyway.
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
    Apr 2013
    Upper Gully VIC
    Quote Originally Posted by Umai Naa!! View Post
    Have a look at the Autel units.
    And thankyou for this suggestion too.
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by aSimpleLife View Post
    That's annoying for sure
    I would have recommended ODBLink - rock solid device with fast communications (you can actually do live monitoring/tuning)
    Trouble is they are getting pricey now - more expensive than low end Autel
    Perhaps this one is worth a try
    Super Mini ELM327 Bluetooth OBD2 Scanner Diagnostic Tool FOR BMW VW Audi | eBay
    Apr 2013
    Upper Gully VIC
    OK I will give that a try thankyou.
    Mt Cotton
    The same OBD11Scanner device came with our Chinese replacement DVD GPS head unit , you plug it in and go to the app on the head unit {Android 5.1} and you can see the readouts etc without a laptop or other mobile device . Scroll down to see the app in the photos 8"HD CAR Stereo FOR Passat CC Golf Touran Jetta Seat DAB OBD GPS Wifi 3G 3015AM | eBay
    Dec 2008
    Sydney/Canberra
    Autel MD802 All Systems is what I have at the moment.
    It's the best value for money one they have. It's not bi-directional, nor does it have an oscilloscope function, but it does the job. Was around $400 from memory, and came with a while heap of brand-specific adaptor plugs.
    It'll scan and clear codes from all modules, and can reset service lights, and even change the intervals on VWs.
    Mar 2008
    V-CHECKER Reader Volkswagen Professional VAG
    I have one of these. It's okay for the price. Scott
    Mar 2008
    V-Checker V202 - KWP2000 + KWP1281 + CANBUS
    Looks like the latest version. Picks up faut codes and do coding, active monitoring, coding etc although instructions a little limited.
    Scott
    Apr 2013
    Upper Gully VIC
    I had completely forgotten about my posts and the advice here. Based on the info I can still see, would this still be my best option now for reading and clearing codes for a 2010 T5.2?
    Autel MaxiDiag Elite MD802 All System for $296
    Dec 2018
    Perth
    Has anyone tried one of these VW-specific scanners from souped.com.au?
    They look suspiciously cheap for AU$80, but you have to select your make/model, so maybe they can make money because your scanner only works for a single vehicle?
    It's almost worth a crack at that price... Unless anyone has tried one and had them not work
