Results 1 to 3 of 3
Thread: Broken electric window
    Jul 2010
    Wanneroo, Perth
    Hi guys,
    I'm a bit stuck. I went to wind the drivers window down and heard a clunk and the window dropped to half way and is stuck there now...... S**T.
    I took off the door trim but i can't see anything due to the sheet metal panel in the way... i'm good with tools and fixing things but are non professionals able to play with this stuff?
    I had the passenger electric window fixed this time last year and it seems to be the same problem (that cost me $650 to be repaired and don't want to be hit with that bill again if i can fix it myself).
    Any help is much appreciated guys,
    Kevo
    2004 VW T5 2.5 TDi SWB
    Jul 2010
    Wanneroo, Perth
    Ok, once this breaks there is no way you can get around fixing it properly unless you guy a whole new inner door again (the complete new metal sheet with all the motor and cables on it).
    Cost me $590.
    VW you make **** electric windows hey
    Jul 2005
    Newcastle, NSW
    Woah, that is pretty extreme. What's the actual part that failed in your cases?
