Results 1 to 10 of 12
Thread: Boost pressure problem
    qls
    Cool Boost pressure problem
    I have had this problem, Glow Plug light comes on, turbo stops working, cruise control stops working.
    Error message when scanned was:
    Tuesday,11,June,2013,11:36:10:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 7H - VW Transporter
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
    57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ9H087280 Mileage: 191130km/118762miles
    Address 01: Engine Labels: 070-906-016-BPC.clb
    Part No SW: 070 906 016 EC HW: 070 906 016 EC
    Component: R5 2,5L EDC G000SG 2539
    Revision: --H07--- Serial number: VWZ7Z0H0433216
    Coding: 0051072
    Shop #: WSC 02756 790 00000
    VCID: 55AB9F8DFF1A771
    1 Fault Found:
    000568 - Manifold Pressure / Boost Sensor (G31)
    P0238 - 000 - Signal too High - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 181
    Mileage: 185839 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1323 /min
    Speed: 52.0 km/h
    Load: 7.5 %
    Voltage: 14.52 V
    Bin. Bits: 00101100
    Absolute Pres.: 1060.8 mbar
    Absolute Pres.: 2580.6 mbar
    Any help appreciated
    regards
    Chris 2008 98 kw caravelle
    Mar 2013
    Brisbane QLD
    just to start with take the 2 screws out of the coolant tank and move to one side.. below there you will see a turbo pipe with the pressure sensor fitted into it... check the connector plug especially the end wire..the brown one... ive had to repair about 5 of these due to being broken off right at the connector housing...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    qls
    will do that, should have given a bit more info, as soon as I start of the glow plug light will come on and no turbo, however after driving for approx 1 hour, have turned car off for fuel and when restarted no glow plug and car goes very well indeed, then maybe 2 hours later the fault reoccurs and will not clear it always seems associated with backing off the throttle not accelerating.
    regards
    Chris
    qls
    regards
    Chris
    Mar 2013
    Brisbane QLD
    check the wire first mate and then we will go further into it... make sure you give the wire a little tug as ive seen a couple just held on by a strand or 2 inside the plug... VDUB..
    qls
    I have had a quick look, the sensor wires have electrical tape around them, but I got no further as had to go some where.I had this problem once before and the ultra tune bods must have had a look here as well. Will have to wait until weekend. thanks so much for these responses
    regards
    Chris Clarke
    Mar 2013
    Brisbane QLD
    take the tape off.. ive also seen a poor repair fail! VDUB...
    qls
    broken wire, red with green stripe, going into no. 4 slot.
    this is a tiny wire what is the best way to fix it, (looks like it was repaired last time)
    regards
    Chris
    Mar 2013
    Brisbane QLD
    thats the one! slot 4! depending on the amount of wire from the plug you may be able to join with a crimp heat shrink connector or vw sell the pint cimplete with about 20cms of wire attached...VDUB...
    qls
    I have all the bits and a soldering Iron and will do the work this weekend
    chris
