Results 1 to 10 of 12
Thread: Boost pressure problem
    Mar 2013
    Brisbane QLD
    check the wire first mate and then we will go further into it... make sure you give the wire a little tug as ive seen a couple just held on by a strand or 2 inside the plug... VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    qls
    I have had a quick look, the sensor wires have electrical tape around them, but I got no further as had to go some where.I had this problem once before and the ultra tune bods must have had a look here as well. Will have to wait until weekend. thanks so much for these responses
    regards
    Chris Clarke
    Mar 2013
    Brisbane QLD
    take the tape off.. ive also seen a poor repair fail! VDUB...
    qls
    broken wire, red with green stripe, going into no. 4 slot.
    this is a tiny wire what is the best way to fix it, (looks like it was repaired last time)
    regards
    Chris
    Mar 2013
    Brisbane QLD
    thats the one! slot 4! depending on the amount of wire from the plug you may be able to join with a crimp heat shrink connector or vw sell the pint cimplete with about 20cms of wire attached...VDUB...
    qls
    I have all the bits and a soldering Iron and will do the work this weekend
    chris
    qls
    Bought the plug & 4 wires from VW cost $55, soldering Iron and solder $20, electrical tape $3.50, vag com diagnostic from UK $125, did the work day and problem so far fixed and all codes cleared.
    Thanks so much for the help
