Originally Posted by
Sunny43.5
NOT one of them will tell you how to dissasemble something if its BROKEN .
Many moons ago, I owned a 356B Porsche [actually I owned it twice], that had instructions on installing a hidden wire in case the main bonnet release cable broke. A hole was drilled in the inner guard. I wire connected to the catch was fed through the hole, fixed somehow & painted over with body underseal/deadener. Mine was only 6 years old when I bought it & some previous owner had already carried out the factory suggestion or maybe they finally came out of the factory that way.
I had the bonnet up on my T4 yesterday after completing a water pump & belt change with lots of help from farmsyncro & had a quick look at the catch to see if I could see a way to open when the cable no longer works.
I will be interested to read how the OP comes up with a solution.
Numerous Mk1 Golf diesels
