Results 1 to 8 of 8
Thread: Big Problems
    red_t4 Guest
    Big Problems
    Ok a mate has a 1997 2.0 (i think) petrol t4. 5spd manual. 217000kms
    first problem, the engine seems to hunt and miss, idle is crap, every 5 seconds seems to almost stall then rev back up. acceleration is jerky.
    second but main problem
    gearbox lost reverse not long ago, and 1st and 2nd went to the position where reverse was, this lead me to assume that the linkages had gone wacky. sent to basic mechanics who lubricated something dont know didnt ask the friend precise details, and now the only gears available are 3rd and 4th. anywhere on the gear lever up is 3rd down is 4th.
    See how you go with this one
    Thanks
    Tim
    Jan 2007
    South Australia
    Welcome to VWwA Tim
    The T4 Advisors will be here shortly
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Jun 2007
    Melb.
    I seem to remember a similar problem...looking at service records now @ 246,894km I lost reverse and had trouble getting anything else...after repairs it was a broken bush and ball socket linkage for the gear lever leading into the gearbox. This was replaced with a new part and all up it cost $128.48 precisely back in sept '05. IIRC you could just make out the linkage if you looked down through the engine bay to the rear of the gearbox...using a torch...as the protection plate under the engine blocks your view from underneath and had to come out as well.....I hope this provides some help.
    ps. the actual bush and ball socket only cost $17 back then...labour while at a cheap rate took a while for a local non-experienced VW mechanic at the time.
    red_t4 Guest
    Thanks tornado, ill look into that, hopefully that is the problem certainly would be better than a tranny reconditioning.
    Thanks for the welcome Ben
    Tim
    red_t4 Guest
    instructions
    btw, can anyone instruct me on how to put a new bush and ball in? or push the old one back in its socket if its come out?
    Thanks
    Tim
    Apr 2006
    VW Race HQ - Sydney
    pull the whole linkage out and push the ball and socket in properly in a vice , Ive tried doing it on the car and sometimes it pops out after a few k's . The shaft comes out towards the back end of the car , its tricky but worth doing it the long way
    vwrx Guest
    This bush cannot be inserted fully in the vehicle, it must be pressed in with a vice, When i did mine( and it is a bugger of a job) i also had to realign the neutral position afterward.
    red_t4 Guest
    ok in the end i found out that the mechanic that worked on it has no idea about working on vw. the ball joint socket is fine, so ended up getting 1-4 back but only just. the friend is gonna take it to proper vw mechanic and get it sorted.
    Thanks for continued replies
    Tim
