Results 1 to 10 of 36
Thread: Best T4 for camper.
    Jul 2005
    Quote Originally Posted by muz View Post
    Thanks for the info guys. I have always had a weird feeling about converting an ambulance though. Bad vibes!
    Each one is supplied with its own Nurse
    Maris
    May 2006
    Adelaide South Australia
    The TDI 2.5 was fitted to the T4 in Europe in '96 but didn't arrive in Aust. until 2000. By then there was a trend towards auto boxes.[Syncro was only available with a manual box] As a result the manual with the TDI will be harder to find. As seano has said the autos are expensive to fix[around $6000] However I have heard of a problem with the manual where the owner had to source another. They are also expensive to repair & don't forget slave cyl., clutch & flywheel. If you buy a good one they last well[manuals & autos] but when you buy secondhand a few years old it's the luck of the draw.
    Rova, you mention maintenance costs. Without going into details I would think the petrol & tdi would be much the same.
    Here's some positive comments about T4 transmissions, most behind V6 motors. Remember the milages are in fact miles not kilometres[multiply by 1.62]
    http://forums.vwvortex.com/zerothread?id=4204570
    Numerous Mk1 Golf diesels
