The problems listed on the Brickyard site are an extreme view. Written by a mechanic, they are the sorts of things he has repaired. There would be thousands out there that havn't had those problems & if they did, only at very high mileages.I don't agree with items 3,4,5 & 6. While they can occur, he should have left off the words "lots". Probably the only item on that list that can be a common failure is the brake light switch, & thats cheap & easily fitted.The clutch pedal box & ignition switch will eventually fail but normally at high mileages. Keep in mind a lot of T4s are used as a commercial vehicle,over loaded & driven by someone who doesn't own it & flogs it.
All the motors [not sure about the V6] have timing belts that can break, like most cars on the road today. If you maintain the vehicle like you should then it's all good. Some people think you can keep driving , without doing anything until it stops. I read recently where someone had a ribbed accessory belt shread & go under the timing belt. With regular inspections this sort of thing should not happen.
Numerous Mk1 Golf diesels
