Results 1 to 4 of 4
Thread: Best sound deadening pads?
    Oct 2017
    Looking to start work on the van and first thing is sound proofing and carpets.
    Best products for the sound deadening? So much to choose from I would rather see what people recommend. Same with carpet.
    Cheers.
    Mt Cotton
    Well from a motor trimmers point of view after being in the industry for close to 40 years my recommendation is what we used to call Triflex . Its also known as carpet underlay but has various names , it is made up of various materials that has been shredded and then blended together and ends up in roll form so you can buy buy the metre Underlay 900 gsm | Nolan.UDA . Now as I have done many vans with this product I believe it will give better finish than Soundmat / Dead sheet or any of those stick on ones . When used in tandem with blocks of foam cut from an old 4 or 5 inch foam matress the sound deadening is amazing .. You will need a spray gun and acompressor to spray the glue , check out the sticky thread I posted to see some work I did on a T5 LWB a few years back Insulating T5 "Another wet weekend and someone is getting a makeover" The carpet used on the side walls is called Hull Liner again from Nolans it stretches quite well as you will see in the photos , but no good for floor I usally buy a household or commercial carpet from a carpet store . They have loads of remmnants at cheap prices and its as tough as nails . This is our family van I set up to carry our two disabled kids in wheelchairs , whilst our eldest son passed away just over a year or so back we still have our daughter . It is also used to carry our camping gear and acouple of mates when we go Moto Cross riding so it is a good allrounder in the comfort department New T5 Project. Send me a message if you want to discuss any mods trim wise , I don't do conversions any more so you could do it yourself or a local trimmer could do it for you , I am more than happy to offer advice . Howard
    Jul 2016
    I used Resomat to line the whole van Resomat Premium | Tru-Fit Carpets
    I also went with a reflective 10mm self adhesive closed cell foam over the sound deadener , then a 4mm closed cell reflective foam on the back of the plywood panels to give a cavity between there chassis and the panels.
    I then used Autex Flex carpet (hull liner) which is available from Nolan's in Brisbane.
    I went this way as it better suited my needs as a camper van, and reducing the condensation issues while sleeping in the van. (closed cell foam doesn't absorb water and will dry out faster)
    Howard's way would be a lot cheaper and faster.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Oct 2017
    Well from a motor trimmers point of view after being in the industry for close to 40 years my recommendation is what we used to call Triflex . Its also known as carpet underlay but has various names , it is made up of various materials that has been shredded and then blended together and ends up in roll form so you can buy buy the metre Underlay 900 gsm | Nolan.UDA . Now as I have done many vans with this product I believe it will give better finish than Soundmat / Dead sheet or any of those stick on ones . When used in tandem with blocks of foam cut from an old 4 or 5 inch foam matress the sound deadening is amazing . Underlay 900 gsm | Nolan.UDA . You will need a spray gun and acompressor to spray the glue , check out the sticky thread I posted to see some work I did on a T5 LWB a few years back Insulating T5 "Another wet weekend and someone is getting a makeover" The carpet used on the side walls is called Hull Liner again from Nolans it stretches quite well as you will see in the photos , but no good for floor I usally buy a household or commercial carpet from a carpet store . They have loads of remmnants at cheap prices and its as tough as nails . This is our family van I set up to carry our two disabled kids in wheelchairs , whilst our eldest son passed away just over a year or so back we still have our daughter . It is also used to carry our camping gear and acouple of mates when we go Moto Cross riding so it is a good allrounder in the comfort department New T5 Project. Send me a message if you want to discuss any mods trim wise , I don't do conversions any more so you could do it yourself or a local trimmer could do it for you , I am more than happy to offer advice .
    Howard
    Thanks Howard
