Results 1 to 7 of 7
Thread: Battery replacement registration/coding
    Mar 2008
    Hi all,
    I am seeking advice on a definitive date T5s require coding/registration to account for a new replacement battery? Is this required for a 2008 model?
    I am sort of mystified by all of this, and isn't battery charging from the alternator adjusted according to battery level? This was never a thing with older vehicles, where batteries were simply replaced!
    Cheers,
    Scott
    Dec 2008
    Sydney/Canberra
    Not required on a 2008.
    Put the correct battery in, and away you go.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2008
    Thanks for the quick response! I put a new correct spec Varta in about a week ago.
    Cheers,
    Scott
    Mt Cotton
    All you may need to do is reset your power windows by driving them to the close point and thats it ,also code the radio but you should have its code in the owners log books .
    Mar 2008
    Thanks Sunny. Radio/CD keeps it presets on mine, and windows sort them shelves out after a few goes. Still chasing a voltage drop per separate post.
    Mt Cotton
    Quote Originally Posted by Umai Naa!! View Post
    Later VW models were a bit fussy when you fitted a new battery , when I sold my sons GTI the battery had died so I wasn,t prepared to spend over $500 on a battery just for the start stop system . Fitted a new one and the auto guy said it would throw up a few fault codes which then dissapeared a few kilometres down the road , sorted itself out .
    Mar 2008
    Fair enough Sunny.
