Results 1 to 10 of 14
Thread: Awning Brackets Without Roof Racks?
    May 2013
    Not far from Cooma
    Has anyone successfully mounted a side awning to some stubby brackets that fit in the roof channels without the need for roof racks? I don't want racks for our van and ideally would like to be able to mount an awning using 2-3 mounting points in the left side rail of the roof. This awning could then be reasonably quickly fitted and removed when needed.
    Or does pretty much everyone just bolt them to the side of their roof racks which live on your vans?
    Cheers,
    Tony
    Mt Cotton
    With our older T5 we had an awning on the side , what I did was to get a length of what is called "sail track "its used in caravans etc to attach canvas to vehicles vans boats . It is the same as this one 2m SAILTRACK ALUMINIUM Single Flange Sail Track Shade Awning Keder Caravan Mill | eBay There are several sealed bolts on the outside of the roof just over the top edge , I used these screws to hold the track to the roof . Once its bolted you cannot see it from below as its in the recess , you can then slide your roof cover into the track and put out your poles . Obviously this is not a folding frame method like some but it is cheaper to do . Our side cover was the same width as the dimension of the roof from the tailgate to the front windscreen , ours was a bit longer and we used to tie off the ends so it gave good coverage . The distance out from the van was around 6 metres and we made side walls to fully enclose it in bad weather .
    Feb 2008
    Adelaide,Oz
    I have a canvas awning, that mounts to "sail track" and a 25mm square section beam.The frame(25mm square) for the awning mounts to the points in the roof gutter at 3 places front and rear( 2 each nearside,1 each farside).I just unscrewed the bolts there and replaced with threaded rod and wingnuts.The frame pieces triangulate to the far side gutter for strength, when tensioning the awning.The whole awning, (almost as long as the van) can be rolled up via a handle on the beam, and fitted inside, just.The frame folds up also
    Awning Brackets Without Roof Racks?-van-awning-800x600-jpg
    Steve
    04 T5
    Dec 2008
    Sydney/Canberra
    Fiamma does a T5/6-specific bracket that utilises the factory bolt holes in the roof channel. Not sure how universal it is with other awnings though.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2016
    Similar to Sunny, I made mine from 40 x 25 aluminium angle and 90 degree sail track. $60 from Ullrich aluminium for 6.5m of each which is enough for tracks on both sides of the van. I also had mine powder coated black to keep my van as a bit of a stealth camper as well as aesthetics.
    I've had on vehicle awnings and prefer just having folded canvas as it has multiple uses and allows for more versatile configurations. I will post photos in a couple of weeks as I'm in the process of having my previous awning canvas remade (10 years old and this is the 3rd vehicle that it'll be used on!).
    I've got mine under the roof racks, but where there is no rack in the third hole it is held in with the stock screw which you could do for all of them.
    Awning Brackets Without Roof Racks?-dsc_4943-jpg
    Awning Brackets Without Roof Racks?-dsc_4948-jpg
    Dec 2008
    Sydney/Canberra
    Does it whistle at speed?
    Might be something I'd consider doing, as I can't justify the $800 or so on something low-profile that will probably get pinched anyway. I can't run anything too universal that requires roof-racks, due to height limitations at some job sites.
    '01 Beetle 2.0
    Jan 2010
    Melb Westsideeeee
    Quote Originally Posted by Umai Naa!! View Post
    As far as I know, the Fiamma ones are pretty universal across most mate, and at worst case you just drill the new mounting points into the bracket. Pretty straight forward.
    I am planning to get some Fiamma mounts just because how tidy and tucked away they are!
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Dec 2016
    Remembered to check this yesterday and couldn't hear any whistling at speeds up to 130.
    I was able to use my hand to manipulate the air and get a very minor whistle out of it so it's possible in some situations it would whistle.
    I also modified mine to bring them 100mm further forward in the track.
    Awning Brackets Without Roof Racks?-dsc_4954-jpg
    Awning Brackets Without Roof Racks?-dsc_4964-jpg
    Dec 2008
    Sydney/Canberra
    Nice work, thanks!
    Definitely looking into this now.
    '01 Beetle 2.0
    Dec 2016
    I used 90 degree offset sail track. Standard sail track (bunnings, etc.) would still work, but would be a bit awkward.
    Extrusions
    UA1068 - 40 x 25 x 1.6 unequal angle
    Extrusions
    UA10054 - 28.50 x 11.25 offset sail track
    Canvas work is starting today so I should have some pics soon.
