I'm interested in a TDi upgrade that comes out of the UK that involves the change out of the stock diesel injectors and a ECU re-map. The engine involved is the regular 2.5 TDi engine ACV type as fitted to the T4 between 2000 and 2004. The new inejctors are the 0.264 injectors from Kerma TDi or similar (these are the same injectors that were fitted to the 150 bhp T4 only available in the EU). Apparently all that is immeadiately required after fitting is an idle adjustment.....although some drivers are saying that significant black smoke is created at times until the remap is done.
The lads in the UK are claiming 155bhp after the re-map (mid 140's before with some smoke) with no other mods necessary.
Thus far the UK boys seem to be suggesting that only www.chipwizards.co.uk can successfully do the remap....
Without someone to do it here then this mod is dead in the water...
