Results 1 to 10 of 17
Thread: Any problems with the Hayman Reese hitch for a T5?
    Nov 2008
    Corinda, QLD
    Hi Guys
    I'd like to fit a towbar (or really, a hitch receiver) to my T5 Transporter. Its mostly going to be used to cart pushbikes around.
    I've read the earlier threads on VW's extortionate charges for the stock towbar.
    I've had two companies quote around $795 fitted including harness for the Hayman Reese hitch receiver.
    Any reason to go for the VW OEM part over the Hayman Reese?
    Thanks
    David
    Canberra
    I believe the really expensive bit is the control unit that connects the trailer electrics to the van's can-bus electronics. But I have also read somewhere (can't remember where) that you only really need this if your van has ESP, otherwise any competent sparkie can just connect it up using relays.
    A search may thow up some useful threads (but go into advance search and change the date to any date, otherwise you only get threads less than 6 months old).
    Nov 2008
    Corinda, QLD
    Thanks for the comments. I did read the older thread (with people being quoted > $1600 for a VW Towbar fitted!), and there was one person with a Hayman towbar he used for towing a caravan as he wanted the full 2500Kg towing capacity.
    I'm curious if there is any difference electronically between the VW bar and the Hayman Reese bar. My van does have ESP but I'm not sure how much this would be affected in my case (I'll have a number plate bar attached but no trailer).
    Both suppliers stated that the installed cost included the harness - and at $800, this seemed a hang of a lot better than the VW costs.
    Is there any reason to pay the extra for the VW bar?
    David
    Adelaide hills, SA
    Quote Originally Posted by dct View Post
    David
    Peace of mind? Knowing, that it is going to work with the ESP.
    Aug 2008
    What is ESP?
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Canberra
    Quote Originally Posted by Ivo View Post
    What is ESP?
    Electronic Stability Control - the car has various sensors and applies the brake on individual wheels to stave off impending disaster, and will also reduce engine power if it deems necessary. Basically it tries to save idiots from the consequences of their bad driving decisions, but it can't save anyone from the basic laws of physics (go too fast around a corner and you WILL crash).
    Aug 2008
    Do I have ESP on my van? I know its got traction control as it kicks in sometimes on when accelerating on slippery surfaces.
    Why is ESP a problem when towing? Does it effect the electric brakes on a trailer? What if I'm just towing a box trailer to the dump or my 14ft tinny around that dont have electric brakes?
    Canberra
    IIRC, if you have a button labelled "ESP" or a diagram of a Car with squiggly lines (like it is skidding), then you have proper ESP.
    If you have one labelled "ASR OFF" then you don't have ESP, just EDL and ASR (the power reduction you have already noticed).
    My van doesn't have ESP, but seeing as yours is a Multivan it may have ESP as standard equipment.
    I'm sure the different functionality of ESP, ADL, ABS and ASR is described in your owner's manual.
    My understanding (and I could very well be wrong), is that if you have ESP on your van the parameters are changed when you tow, as a van with a trailer on behaves differently to a van without a trailer. The ESP controller probably behaves more conservatively with a trailer hooked up.
    I don't think towing a trailer with or without electric brakes is a problem for the ESP controller, more that it needs to know whether you are towing or not.
    Nov 2008
    Corinda, QLD
    I hadn't heard the ESP reason before - just comments on the reversing indicators being disabled.
    I'm not sure how the ESP would know what to do, given that the "load" in my case will be a Thule rack with 3 bikes but it could equally well be a 2500Kg caravan.
    Anyway I think I'll take the risk...
    Thanks
    David
    Jun 2007
    Melb.
    If you don't have factory installed reverse parking sensors then I'd go the H-R option. I have one on my van with a step and rear protection bars, 250 tow ball weight and 2500kg tow rating although I'd never tow that much. I should have had the factory wiring loom dealer fitted to automatically deactive the rear sensors when a trailer is installed however they installed a round pin which doesn't have an internal switch to send a signal that a trailer socket has been connected. Dealer fitted a seperate switch for me to turn off the rear sensors. I do have ESP and haven't heard about this mentioned when talking tow bars and the factory wiring loom. It may have a bearing on the ESP calibration although I thought I read that this feature (an ESP setup which catered for towing) was a T5 update feature..
