I suspect so. I ran a set on my T5 running 255/45 Bridgestone Podenzas which gave me the same rolling diameter as my 16s.There was a minor amount of rubbing on full lock in one direction - I forgot which. Otherwise they were perfect.
Hi, Does anyone know if a set of 18 x 8 Amarok rims will go directly onto a T6 multivan?? I have done some reading on this and from what I understand they will. Any advice appreciated. Thanks (posted this earlier to the wrong forum..sorry)
Great thanks for that! I think I will give it a go.
Offset is different between T6 and Amarok rims. I tried 17" inch Amarok rims, they made hanlding feel wierd, I would guess the same effect from 18" Amarok wheels. I ended up with 18" Multivan original rims.
Multivan MY12 TSI350 Red. Previous: 2008 Tiguan 103Tdi. 2010 Tiguan 125TSi.
Offset is different between different Amarok rims. Look up the specs of each wheel you are interested in to see what offset for that particular wheel is.
About 4 different models of 18" wheels OEM and a few more as original Accessory wheels.
Each wheel have the offset stamped on it on the back.
