Results 1 to 8 of 8
Thread: Air Mass Sensor Pierburg
    byron
    I recently had a major power drop on my 01 2.5 TDI. Did some interwebbing & found a few ideas. Seems my boost had disappeared. I disconnected the MAF for cleaning & testing. Cleaned but cant test yet as i dont have a multimetre. However, afer leaving it disconnected, the car now has boost again & is significantly more powerful. Tested on a nearby hill which it can now climb in 3rd where with maf sensor connected it cannot do in 2nd.
    Anyway, does everybody think this is a dead MAF?
    Also, has anybody used the pierburg repalcement sensor rather than the complete OEM "unit"?
    ps i tried heaps of searches on here & found nothing about these issues
    Adelaide hills, SA
    Faulty MAF sensor will affect engine performance, but it would be better to diagnose it properly before you bin it.
    There are reports that Pierburg MAF sensors are more reliable.
    May 2006
    Adelaide South Australia
    What you have described re. disconnecting & power is restored is the usual laymans/quick test for the MAF.
    If you can access VAG COM here is the confirming test.
    Vag Com stuff. - The Brick-yard
    Numerous Mk1 Golf diesels
    byron
    anybody know best place to buy VCDS(lite?) & cable & the pierburg?
    cheers
    byron
    Pierburg is available through AFI. Around $200
    oem unit is is around $350 exchange through VW
    May 2006
    That's a lot cheaper than what I paid back at the end of '03 for my previous van. A Bosch one through Imparts was $425, genuine around $550 at the time.
    Were you able to get VAG COM?
    byron
    not quite sure what i need in regards to Vag-com . Apparently is now VCDS? Can i change ecu settings with the lite free version?
    May 2006
    I think we are both in the dark. I am not familiar with "lite free version"
    I bought a lead off Ebay & the program of Ross Tech. If you are interested here's some reading for you.
    Ross-Tech: Home
