Results 1 to 4 of 4
Thread: Aftermarket head unit and steering wheel controls .
Sunny43.5 Aftermarket head unit and... 11-03-2017, 10:45 PM
formatview321 Hi, I'm interested in this... 14-03-2017, 08:43 AM
Sunny43.5 Yes both types are what I... 14-03-2017, 09:01 AM
formatview321 Ok, so I found the other set... 14-03-2017, 08:52 AM
    Mt Cotton
    For the past few years I have lamented the fact that the base T5,s don't have steering wheel controls for the aftermarket and factory head units , there were some infrared ones which attached to the wheel but they really needed line of sight to the head units receiver to work properly . Those ones would not work if the wheel was turned while driving and pressing any buttons , now it seems those clever little Chinese have once again come up trumps . These new ones are actually radio remotes so the signal is not affected regardless of the wheel position , a small receiver is fitted behind the head unit via four wires . One to acc one to earth and the next two to the Key 1 and Key 2 wires that a lot of the Chinese head units have built into their plugs . The antennae wire is just left again behind the head unit so its all out of sight , the actual controllers are completely wire free no connections whatsoever to the car at all . I purchased two styles for each of our vans as the both have different steering wheels , one has a single controller which I have mounted between the spoke on the inner side of the wheel . The other one in my wifes T5.1 has two controllers that I have fitted into the side part of the main spoke , where the factory one would be normally . Admits here I should have asked if they have black ones as the white tends to stand out a bit against the wheel , if they have them its a ten second job to switch them later .
    Once the receiver is wired up you simply select steering wheel controls in the settings and just press whatever buttons to match the head unit to the controller . The wife's one has two extra buttons so you can set them for whatever you want . They are also backlit when you touch any button it stays on for a second or so after the button is released . These would probably work with RNS models as well if they have outputs for steering wheel functions . A lot cheaper at $47 delivered than trying to go through the hassle of using VW parts .{Yes I know its not factory so please no haters } LOL
    Aftermarket head unit and steering wheel controls .-20170311_175231-jpg
    Aftermarket head unit and steering wheel controls .-20170311_175338-jpg
    Aftermarket head unit and steering wheel controls .-20170309_175836-jpg
    Hi,
    I'm interested in this as well. Do you have links? Did you find them on eBay/aliexpress/etc?
    I found a link to the lower one on aliexpress here
    I'd like to know where you got the two white ones in the top pick.
    Thanks,
    Mt Cotton
    Yes both types are what I purchased I got both them from this company http://stores.ebay.com.au/hotaudio-s...ub=19672942011 . Obviously prices vary from one shop to the other as long as freight is clear then all good .
    Ok, so I found the other set as well here. However that doesn't seem to include the plastic trim that you have put over the steering wheel. Can I ask where you got that plastic trim? Also which one do you prefer?
