Hi,
I'm interested in this as well. Do you have links? Did you find them on eBay/aliexpress/etc?
I found a link to the lower one on aliexpress here
I'd like to know where you got the two white ones in the top pick.
Thanks,
For the past few years I have lamented the fact that the base T5,s don't have steering wheel controls for the aftermarket and factory head units , there were some infrared ones which attached to the wheel but they really needed line of sight to the head units receiver to work properly . Those ones would not work if the wheel was turned while driving and pressing any buttons , now it seems those clever little Chinese have once again come up trumps . These new ones are actually radio remotes so the signal is not affected regardless of the wheel position , a small receiver is fitted behind the head unit via four wires . One to acc one to earth and the next two to the Key 1 and Key 2 wires that a lot of the Chinese head units have built into their plugs . The antennae wire is just left again behind the head unit so its all out of sight , the actual controllers are completely wire free no connections whatsoever to the car at all . I purchased two styles for each of our vans as the both have different steering wheels , one has a single controller which I have mounted between the spoke on the inner side of the wheel . The other one in my wifes T5.1 has two controllers that I have fitted into the side part of the main spoke , where the factory one would be normally . Admits here I should have asked if they have black ones as the white tends to stand out a bit against the wheel , if they have them its a ten second job to switch them later .
Once the receiver is wired up you simply select steering wheel controls in the settings and just press whatever buttons to match the head unit to the controller . The wife's one has two extra buttons so you can set them for whatever you want . They are also backlit when you touch any button it stays on for a second or so after the button is released . These would probably work with RNS models as well if they have outputs for steering wheel functions . A lot cheaper at $47 delivered than trying to go through the hassle of using VW parts .{Yes I know its not factory so please no haters } LOL
Hi,
Thanks,
Ok, so I found the other set as well here. However that doesn't seem to include the plastic trim that you have put over the steering wheel. Can I ask where you got that plastic trim? Also which one do you prefer?
Yes both types are what I purchased I got both them from this company http://stores.ebay.com.au/hotaudio-s...ub=19672942011 . Obviously prices vary from one shop to the other as long as freight is clear then all good .
