Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Aftermaket GPS navigation with Bluetooth
    Adelaide hills, SA
    It certainly looks good. Could you please post the pictures after installation? I'd like to see how it integrates onto the dash and also hear your feedback.
    Jul 2010
    Mooroolbark, Victoria
    will do, so far only fitted camera, will finish the rest on Monday.
    05 T5
    Dec 2008
    Sydney Australia
    Quote Originally Posted by Colinmc View Post
    I decided to risk getting one from ebay, I found a local supplyer, ended up getting this unit.
    click here
    arrived to my door in two days, in the process of fitting it now.
    Cost $520 with reversing camera.
    Looks good let me know how it goes.
    did you buy a iso to vw wiring adaptor ?
    the bug
    The VW Bug
    2010 Golf 2.0 103kW TDI Manual White
    2011 Multivan 2.0 132kW TDI Sliver
    2018 Multivan 2.0 TDI White
    Jul 2010
    Quote Originally Posted by thevwbug View Post
    the bug
    I just unplugged the old one & plugged the new one in using the same plugs when I tested it. All seems to work, however I will need to put new speakers in the back so may need something to plug them into.
    05 T5
    Apr 2009
    Canberra
    I am keen to see how this unit fits and performs, have been looking at this style aftermarket unit, but as yet not made the plunge!
    Good luck
    06 T5 4Motion
    aka Lola the Tranny
    On the road
    Having used the HEMA Navigator I can heartily recommend them.
    Hema Navigator > Home
    Integrated BT and able to fit reversing cam, good large, easy to read screen, can upload maps including toppographic.
    Not cheap but it's the best unit I've seen (Motorhomes, 4WDs, tour coaches etc).
    "Stupidity is the only universal capital crime; the sentence is death. There is no appeal, and execution is carried out automatically and without pity" R. Heinlein: Time Enough For Love
    Jul 2010
    All fitted. No major problems. I had to change the pins on the plug as the PWR & ING where reversed, also the power antenna pin was in the wrong spot & was getting power so disconnected that as it in not needed.
    The unit did not come with a sleeve to slide it into so I just slid it into the dash & secured it using packing on each side & then cable-tied it in at the back so it can't be remove from the front.
    Touch screen works OK & looks good, although the screen does tilt it is of no use as it tilts the wrong way to angle it at the driver/ passenger. this is because the transporter dash is already on a tilt. Not sure if any unit would tilt the other way.
    RADIO/TV - tuned in straight away & found all stations 18FM, 6AM pre-sets. has radio station names on FM & some station show song playing.
    DVD/USB & SD all worked no problems.
    GPS - the maps that came with the unit were I-GO, I would say the are for a smaller screen & are slightly blocky, radio cuts out during announcements & it tells you when you are speeding according to the current roads speed limit.
    IPOD - I have an iPhone, the blue-tooth worked fine & linked straight away. When I plugged it into the iPod lead a warning came on my phone to say I should put the phone on aeroplane mode. (This often happens when i plug my phone into accessories) The unit seem to only play & navigate the play list that the Ipod is set to when you plug it in. I could be wrong about this I haven't play with that very much.
    REVERSE CAMERA - Shows lines on screen for car width & 1M to 4M lines for distance. Fitted it just above number plate, couldn't find the reverse switch so I ran a lead from the reversing light to the unit so it comes on when reversing.
    [IMG] Uploaded with ImageShack.us[/IMG]
    05 T5
    Mar 2012
    There seems to be a new version of the ELinz device.
    Here
    Anyonje used the new unit in a Tiguan or indeed any VW?
    Thanks
    Mt Cotton
