They look like they'd move around a fair bit when in operation.
If it were mine, I wouldn't be happy.
Wow. So is that hole present in the non-aero wipers on purpose so they can be fitted to the aero-arms? Or is this a total hack?
If those holes are there specifically for this type of situation, maybe it's OK? Then just get the proper aero arms next time using the P/N above![]()
- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
I'm ordering some new blades and had to look up the part numbers again so thought I would add them to this thread to save me the trouble next time around
Multivan (with Aero retrofit)
7H6955409 - Aero Wiper Arm Drivers Side
7H6955410 - Aero Wiper Arm Passenger Side
7H5955425 - Wiper Blade (each)
-=OR=-
7H6998002 - Wiper Blade Set (set with wear indicator)
Rear Wiper:
7E0955425 - Aero wiper blade
Well...I can't believe I've just spent almost $300 on front windscreen wipers !!!
But I can't endure that shuddering anymore - for me it seemed to start within a a couple of months of replacing the current standard blades with after market ones each time.
I also was unable to source the aero arms for a better price from os - can get the aero blades for $20 delivered - but not the arms - so thought I'd start with genuine blades and then compare them with the os after market blades down the track.
Price from FTG VW - I get no discounts - arms $95 each - blades $76
Thanks to all for the info and part numbers - without the numbers the spare parts guy had no idea what I was talking about.
Edit - inc gst...I hope![]()
__________________________________________________ __________________________
VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
while it isn't VW - I have got great results from using the Bosch Aerotwin ones that I purchase from sparesbox.com.au
I've got them on the Crafter, Caravelle, our Rosa minibus and our Discovery. They're around $60 a pair and every time I change them I think "why didn't I do this sooner" !!
My original blades lasted nearly five years!
I ended up getting these as a straight replacement and they've been terrific so far.
(about 4 months now so I can't report on longevity yet)
https://www.wipertech.com.au/2005-cu...ar-door-wipers
2018 Crafter Runner
T5.1 6sp manual.
Well all fitted and it was safe to assume the arms and blades are the same for the Multivan and Transporter
Now I just have to wait for it to rain again.
Yes...well...I must confess that I had missed your initial post in amongst all the enthusiasm for the aero arms and blades
I would have given them I try first.
In fact...in hindsight I probably should have tried a genuine vw set of the original blades first...because the shuddering I was repeatedly getting...may have always been due to using oem blades?
Oh well...at least it was a business expense...
