Results 21 to 30 of 40
Thread: Aero Wiper install T5.2
  1. #21
    Mar 2011
    Gold Coast QLD
    Wow. So is that hole present in the non-aero wipers on purpose so they can be fitted to the aero-arms? Or is this a total hack?
    If those holes are there specifically for this type of situation, maybe it's OK? Then just get the proper aero arms next time using the P/N above
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
  2. #22
    Dec 2008
    Sydney/Canberra
    They look like they'd move around a fair bit when in operation.
    If it were mine, I wouldn't be happy.
  3. #23
    Dec 2006
    Kilsyth, VIC
    I'm ordering some new blades and had to look up the part numbers again so thought I would add them to this thread to save me the trouble next time around
    Multivan (with Aero retrofit)
    7H6955409 - Aero Wiper Arm Drivers Side
    7H6955410 - Aero Wiper Arm Passenger Side
    7H5955425 - Wiper Blade (each)
    -=OR=-
    7H6998002 - Wiper Blade Set (set with wear indicator)
    Rear Wiper:
    7E0955425 - Aero wiper blade
  4. #24
    Apr 2013
    Upper Gully VIC
    Well...I can't believe I've just spent almost $300 on front windscreen wipers !!!
    But I can't endure that shuddering anymore - for me it seemed to start within a a couple of months of replacing the current standard blades with after market ones each time.
    I also was unable to source the aero arms for a better price from os - can get the aero blades for $20 delivered - but not the arms - so thought I'd start with genuine blades and then compare them with the os after market blades down the track.
    Price from FTG VW - I get no discounts - arms $95 each - blades $76
    Thanks to all for the info and part numbers - without the numbers the spare parts guy had no idea what I was talking about.
    Edit - inc gst...I hope
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
  5. #25
    Jan 2007
    brisbane QLD
    while it isn't VW - I have got great results from using the Bosch Aerotwin ones that I purchase from sparesbox.com.au
    I've got them on the Crafter, Caravelle, our Rosa minibus and our Discovery. They're around $60 a pair and every time I change them I think "why didn't I do this sooner" !!
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
  6. #26
    Apr 2013
    Upper Gully VIC
    Quote Originally Posted by The_Hawk View Post
    -=OR=-
    Rear Wiper:
    Was I safe to assume that these would be the same part numbers for the Transporter?
  7. #27
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by aSimpleLife View Post
    That would be a fair assumption
  8. #28
    Aug 2016
    NSW
    My original blades lasted nearly five years!
    I ended up getting these as a straight replacement and they've been terrific so far.
    (about 4 months now so I can't report on longevity yet)
    https://www.wipertech.com.au/2005-cu...ar-door-wipers
    2018 Crafter Runner
    T5.1 6sp manual.
  9. #29
    Mar 2008
    Quote Originally Posted by Silver Caravelle View Post
    Hi there,
    The aero wiper arms weren't on my 2008 Mulltivan either, although they were on some earlier models. I went the cheaper path a bought some Bosch Aero wipers and slotted them on to the existing existing wiper arms. They look OK and perform well. I think they were about $60 from memory. Currently 'free' with Windscreens O'brien if you have any windscreen work done.
    Cheers, Scott
    At the risk of repeating myself from May 2013 further up in this thread, you don't need to change the wiper arms. The Bosch ones fit nicely over the existing arms and look integrated. Mine are still working well.
    Cheers,
    Scott
  10. #30
    Apr 2013
    Upper Gully VIC
    Well all fitted and it was safe to assume the arms and blades are the same for the Multivan and Transporter
    Now I just have to wait for it to rain again.
    At the risk of repeating myself from May 2013 further up in this thread...
    Yes...well...I must confess that I had missed your initial post in amongst all the enthusiasm for the aero arms and blades
    I would have given them I try first.
    In fact...in hindsight I probably should have tried a genuine vw set of the original blades first...because the shuddering I was repeatedly getting...may have always been due to using oem blades?
    Oh well...at least it was a business expense...
