Originally Posted by
Sunny43.5
Ok your stuffed then , the Crab bar would have been the best option if it could be fitted satisfactorily , The position behind the seat back rest is restrictive as you have to allow for the buckle and adjuster . Have you been to a second place for an opinion on the distance issue ? and yes if you wanted to use the seat frame as an anchor point it would require testing or at least a report from the manufacturers to see if they have load test done or specifications . As I said earlier if the seat belt anchor points are in the middle then there could be a remote possibility that the back rest may stand the loads but an engineer would need to be satisfied that it was strong enough .Just a quick one can the seat be slid further forward to make the extra distance required ?
