Ac leak in interior
Hi Dubbers,
Please help I have noticed under my left front passenger side feet I have a leak after pulling away cover it seams that the Ac unit has alor of condensation building up on it which then drips down to floor in cab.
Can anyone help with this one how do I go about fixing this as it is causing a deal issue .
Thanks
Does it have a fully connected drain? My Multivan didn't at delivery.
Need to find the drain hose, and make sure it's hooked up to the evaporator housing, and goes through the floor.
Also need to check that it's not blocked.
- You may not post replies
- You may not edit your posts
Forum Rules
