6Spd Auto flush out.
So as we all no the auto box is sealed for life LOL. I decided to get my oil changed about 6 months ago. It was starting to shudder when changing between 2nd and 3rd. Not always but often enough to know something needed to be done. As you know they can only get about 4lts out when dropping the pan. My oil was black, I had a new filter and gasket fitted and used penrite oil.
There was no change in shifting and the shudder seemed to be getting worse. When I had my water pump replaced last week the workshop said they had a new machine that could flush the entire auto out but it would require a lot of oil. They disconnect the oil lines that go into the cooler/heat exchanger and connect the machine to that. The car is on the hoist with the wheels off the ground. They then start the car and change gears up and down, while the old oil is coming out new oil goes in. The oil coming out starts to change colour and when clean oil is coming out its done. They used 12lts of oil to flush mine.
Only problem was the cooler is made of aluminium and when the hoses were disconnected it tore the threads up. They had to cut new threads to get it back together.
I did not use Penrite oil this time, I used Fuchs 4400 ATF as there is a Fuchs distributor next to the workshop and according to Fuchs, all though not specified this oil will be suitable. The workshop did the same flush with Fuchs on a transporter that was shuddering a few months ago and there has been no problems with it.
I have only just got the van back but have done about 50kms and it has not faltered once. Even on a steep hill that would always cause it to have shudder badly.
I will update this in a few weeks and let you know how its going.
2014 T5.1 Multivan Tuned by Pendle Performance Australia
