Results 1 to 10 of 16
Thread: 60,000 k service, ouch!
    Adelaide hills, SA
    From the specs sheets there are Kombi Beach with 75kW 4 cyl. engines
    Mt Cotton
    Yes I can recommend JMac he has helped me with advice and has serviced my T5 2.0 lt , van he did major service and timing belt and water pump a hell of lot less than VW wanted . As a side line I rang a dealer here in Brissie told them I needed a service done on our other T5 128 TDI model and was told that the timing belt would need to be done cost around $1400 , but what blew me away was I got Jimmy around to quote on same job only to be told that our T5 doesn,t have a timing belt it has a gear driven cam . I just wonder when the dealer was going to tell me the same thing or maybe I would pay the price without asking , nice profit for them if I had let them do it . Also makes me wonder about 3 years ago the water pump started leaking , VW charged $1350 or there abouts for water pump and minor service , when I asked the cost they explained that the engine would have to be removed to do the water pump ?????? .Now I should have been supicious as they rang me later that same day and said it was finished now I never had any way of knowing did they remove the engine or use a short cut and do the pump without removing the engine but still charged the same . Its no wonder people loose faith with service departments . I also read on the Brick Yard today someone in England who did his water pump without special tools or experience and did not remove the engine and it only took him a few hours to do Hmmmmmmmmmmmmm makes you wonder . Howard
    Nov 2007
    QLD
    I thought there was only 5cyl 96kw beaches brought to Australia which have no timing belt, I have one myself and get it service at German Autos Geebung on Brisbane northside now that it is out of warranty.
    Brian
    Apr 2009
    Wynnum, QLD
    Thanks all, you're right Brian, the Beach was only in the 5cyl 96kw to my knowledge. I would have thought the Brisbane VW dealer (won't name) would have known, but hardly suprised. I get crap service from them anyway so feel no loyalty to them, just like the thought of having the same dealership for my service history. Seems like I need to ring around a bit. I will check with both recommended to see what they think.
    Adelaide hills, SA
    I would expect when you ring them for the quote and especially being a regular customer, they would bring your van's specs on the computer screen and qualified personnel should give you reasonably accurate quote.
    sydney nsw
    dont want to scare you, but that aint half what youll pay when you get to 200,000klms
    Apr 2009
    Wynnum, QLD
    Thanks all, as it is a salary sacrifice I need to do 25,000 k's a year so i'm racking up services about a year before they should really be due, should be out of the arrangement by the end of next year, that means that 200,000 k's hopefully will be a very distant thing!
    With regards to the qualified personnel, I hear you, however these are the same goose(s) that each time they service my car they don't even bother to put something over the carpet. Light grey and greasy bootmarks don't mix well! Also don't know if it is just another dealer upsell.
    I will ring around to check it out as there seems to be a mixed response as to whether it is necessary, if so I will see who I get to do the work.
    Also need at least new front tyres, i'm sure the dealers will be wanting a piece of that action too!
