Hi All,
Well I noticed a noise the other day that sounded like interference while listening to AM radio, you know old mans radio!!, a whine/squeak that changed with vehicle speed. Thought it may be a wheel bearing but had a quick diagnosis by VWCC belconnen and he said that the tailshaft bearings were a bit notchy, he hadnt heard the noise before and only had time for a quick drive and check on the hoist so is unsure if that is the real problem but said it wasn,t wheel bearings as the noise seemed to be at a different speed to the wheel motion, more like driveline.
So a quick call to VW, tailshaft is a complete unit, three piece with two bearings, sealed unit $1600 thanks!!
Ah the joys of modern engineering!!
So a major service due, brakes nearing replacement add in a tailshaft, not to mention the heater dial needs replacing and the old girl is losing her shine
I suppose 175000 ks aint too bad but I dont see her staying around too much longer.
2006 AXE 2.5 4 Motion 6M
