Results 11 to 20 of 22
Thread: 2nd Battery in the T6 Multivan
    Jul 2016
    Quote Originally Posted by FUNBUS View Post
    That's a LOT more than I thought. I thought it was a $100-$200 option.
    nothing from VW is cheap.
    i thought the mulitvan with the sliding door had the aux battery as standard....
    Sep 2016
    Brunswick, Victoria
    Yeah I would have loved to be able to add a few options but couldn't wait the 5 months for delivery. So everything is after market.. Will ask the dealership for a quote and see what they say.
    Apr 2016
    Hobart, Tasmania
    Quote Originally Posted by Bryn23 View Post
    I could be wrong. I keep being surprised with by new and exciting gadgets on this van. Do you know where they are mounted. I thought that they are under one of the front row seats. There's not one under either of my seats.
    Adelaide hills, SA
    The battery alone would be more than that. The $500 is actually quite good price. It will cost you more to retrofit, even if you get all the parts at the wholesale cost.
    Jul 2016
    You're not wrong,
    I checked out a T6 multivan this arvo, and it didn't have a aux battery for it under the passenger seat.
    Apr 2016
    Hobart, Tasmania
    Quote Originally Posted by StuJames View Post
    G'day All,
    Has anyone fitted a 2nd battery to the new T6?
    Looking at using the TJM DC charger to run off the primary battery, but need to know what battery fits under the passenger seat.. Anyone done something similar, or have the dimension?
    Stu
    Hey Stu,
    Did you end up getting a second battery fitted to your T6? I bought a car fridge for mine recently, so now I'm pretty keen to get a second battery fitted. I have fitted swivels to both front seats which limits the height of a battery to the height of the seat base. Also the Multivan has electric front seats and a lot of other electrics under the front seats so I'm not sure how it would go for room.
    Cheers,
    David
    queanbeyan, NSW
    Second battery is a stand alone option on Transporter and an inclusive option with the cool box in luggage compartment on Multivan. Rrp for the combined battery/coolbox is about $1300, which isn't terrible. I'm currently working out what options I want when I order my van later this year, lease ends on my current car early next year, and the second battery is on the list. For those who want/need a bigger aux battery there have been some positive comments about Lithium batteries in place of the AGM, I probably won't worry about it until it's battery replacement time.
    Jul 2016
    Hey Stu,
    Cheers,
    David
    Hi David,
    With the T6 a lot of DC-DC chargers, they don't work right, due to the low voltage alternator, so just bare that in mind.
    Ctek, are bringing out a low voltage D250s in May i think, Redarc do a LV Dc-Dc charger, i'd be looking for one with lithium capability for the future (Pro Power have a 100ah lipo4 that will fit)
    I don't have all the heated seats, but i do have the captains chairs, and i believe, the same swivel seats as you and the factory VW second battery which doesn't hit the swivel mount, about a 10mm gap.
    If you can't fit it under the seat, i'd be finding a place in the rear.
    It's a pain to get to the battery under the seat, now that the swivel seat is attached
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Apr 2016
    Hobart, Tasmania
    Quote Originally Posted by irsa76 View Post
    Thanks for that info irsa76. I didn't buy the coolbox option because I wanted to get a fridge/freezer rather than the coolbox. I wasn't aware that the second battery setup came with the coolbox or I reckon I would have bought it. The salesman obviously wasn't aware either. Anyway, at least I now know that it's an option for the Multivan so I'll look into getting it through VW. It will no doubt cost a lot more than it's worth, but at least it won't void the warranty.
    Cheers,
    David
    Apr 2016
    Hobart, Tasmania
    Hi David,
    Thanks for that info Bryn23. It seems that getting a second battery is at least achievable for me still. I'm inclined to go with the VW option if it is affordable. Saves warranty problems. Apart from the batteries, do you know if the electrics and fitment of the aftermarket models are far superior to the VW system, or are they pretty well all the same.
    Cheers,
    David
