Faulty coil?
Regards,
Scott
Hi guy's,
Can you help with the :-
NO IGN HT :-
Got a fault on my UK Spec 1996MYR 2.5 Eurovan Siemens 5WP4 240 eng ECU with VW pt no 023 906 024 t.
Have done the hall effect tests, result was got a +5v -0v square wave at ecu green white wire.
Got +12v to coil but get NO switching of the Green wire (tested continuity of wire to ECU ok.
Fitted new GND wire to pin 24 (1.5mm brown wire)found 4.5 ohms resistance btween wire and gnd with ecu m/plug disconnected and testing it to battery neg post..not sure of this wires function ??? any thoughts.The main heavy Brown GND wire to the ECU is ok ..goes to a stud next to the ECU. Coil GND wire is ok ..same gnd point.
Tested ..result was as before get a 1sec HT at plugs then nothing !!!
Do not have a full pin out of the ECU's I/O's can any one help?
The main IGN +12v input to the pin 23. ECU , has no voltage with the IGN ON !! any idea where in the fuse box the black/yellow ??? gets its feed from RELAY ETC ?????/ tested continuity of wire the from the fuse box white m/plug to the ECU conn is ok
IGN +12v is ok on PIN 8
I am trying to test the all the I/O's to the ECU before condeming the ecu !! found surface corrosion the ally housing but pins are clean and no sign of water ingress when took the casing off for inspection .
Sorry about the long post : )
Any tips or guidance on this would be much appreciated.
Regards
Derrick
Faulty coil?
Regards,
Scott
Not sure of the significance of many of your measures but given the known long term unreliability of the VW ignition switch.......that'd be the first thing I'd consider.
...and then I'd take up Silver's suggestion about the coil.
Where are you zola? update your location. THere may be someone round the corner with test gear.
Relay 167 in the bottom right of the fusebox controls the ecu.
I`d still try the coil first, they are notoriously bad.
