Should be fine, these things are like a Panzer tank when going, you just need to watch for the common issues:
Oil and water mixing ( water pump leak ), airbox back pulsing ( cam wear ), exhaust manifold leaks from warping / cracking, and if ever you take the cam out, I'd consider the injector bridge to hold those toggling injectors still! Keep the auto gearbox cool if you have one and do partial fluid and filter changes often! Keep up your engine oil changes, and given the dodgy plated bores I'm running Lucas upper cylinder lube each tank full.
My van is going like a trooper now, but given how much is new in my god damn engine bay, you'd expect that!
