OK been a while but I've still had no luck getting it to actually go.
The mechanics Taiwan "HCB-B1419" tool set ( $1k ) definitely puts the cam several degrees more advanced ( clockwide ) compared to the China tools, but there is a fair bit of freeplay in the China cam tool. This fancy tool set still shows no special TDC on the crank, so I'm at a total loss what VW were on about. Mechanic suggests 5 cylinders is the reason, but the better tool has no specific TDC.
I plan to spend this weekend diagnosing the injectors, as I pulled them recently and three had surface rust on the god damn tips thanks to all the rain we have been having. I wire brushed them back to shiny and penetrating oiled them, but the actual injector holes may be rusted up, so I've got to pull the inlet and see if fuel spray is coming out of each inlet hole. I've three good old injectors so may swap them back in just for ****s and giggles.
I'm still convinced there is something wrong in the fuel circuit given the fact the return line is pressurizing, gonna drop the tank and pull the pump and test it. Still should at least start a bit though. That too makes no sense.
PD injectors and the internal nature of the loom and fuel supply make it hard to diagnose, but I have put my multimeter across all the wiring and checked for continuity. I guess a oscilloscope is the next thing to check they are actually firing.
Probably going to have to send the injectors back to the UK to get them tested, will be the quickest and most reliable way, my VAG mechanic doesn't know of anyone decent who does PD injectors in Australia.
I've got all new stretch bolts so my final step is to pull it down to the head gasket and get my mechanic build it up from there bit by bit.
