Jesus H Christ I'm a loser. Spent the weekend trying to prime the fuel rail and injectors, diesel all over me, the car, and half the suburb. No start. A spray of "Start Ya Bastard" with the glowplug unplugged, and she gives a rev. Been pondering this half of today, spent hours re-reading forums, watching YouTube, then finally re-read both the manuals and guess what, the penny dropped, I skipped a step in the timing process in this weekends last cam install check. The small round crank turning tool does indeed have a TDC mark, but as the crank spins TWICE as fast as the cam, you have to THEN check that TDC with the big crank and pin into head tool, if the pin does not fit in the engine mount bolt hole, you have to turn the crank another revolution!!!! I've not thought that through, been skipping the second big tool and pin check, and I bet my left testicle I have the engine to cam exactly 180 degrees out. It's not hitting valves as I'm indeed using TDC on the crank turning tool, but the injectors will probably be firing at bottom of the stroke! Don't skip steps people, nor think you are smarter than the laborious timing process and tools.
To be fair there's quite a debate up on the UK T4 forums about this, and two guys who obviously know the engine well go back and forth as to if you can indeed get the cam 180 out, and I can see both sides to that argument, plus this whole post is just my conclusion why it won't start, could be wrong....but need to recheck the timing!
SO, more late nights pulling it apart yet again because I'm dumb, and thought I was smart.....wish me luck.
