Spoke too early about no VCDS errors, they popped up after a few small runs!
Well some more developments, and a few more parts in the post from the UK. Turns out I have at least one injector down, if not two. Would seem the "tractor" feel my van has, and it's lack of performance is because one or more cylinders isn't doing much. I tried a "diesel purge" you read about online with the Liquimoly can of cleaner you circulate through the fuel rail, and had surprising results, at first I had cylinder one injector maxing out at the +2.99 mg/stroke trim, and after purge, had #4 trim right out as well!
Very odd, but to be fair I was seeing "multiple misfires error" in that first reading, and the trims sure move around a lot from cold to warmup, but it seems once an injector exceeds the 2.99 max positive trim the car freaks out, and it's time to replace or rebuild them, after investigating other possible problems with that particular cylinder starting with compression!
In the below screen shot, Left side was pre purge, right side after ( to be fair measured while running ON diesel purge ) but levels remained the same on normal fuel afterwards. Car probably needs a bit of a drive to relearn injector trim properly, but I bit the bullet and got two used but tested injectors out of Darkside, I obviously need at least one.
Took me a while to understand all this, but basically positive is bad, as the car is holding the injector open longer to account for a perceived problem in that cylinder, and that can be compression, valve leak, injector, cam issues, you name it. Injector seal and even injector fuel supply / drain can be the issue, and in my T5 they have to be set at a very specific angle, no doubt to get the fuel supply / return ports to line up to the tiny holes in the injector body. Seems anything up to about +1 is normal build variation, and after about 2 you are looking at trouble pretty soon. At +2.99 you get misfire errors.
EDIT: On reflection, I think my WHOLE problem was the injector bore wear and consequent fuel pressure leak, and the probably FINE injectors were maxing out trying to provide adequate fuel. Before you go down the road of buying new injectors, pull them out and have a real good look for injector bore wear in the head, tons of pics coming up below. I feel I wasted $2k plus on recon injectors, when I should have just got a new head first given the bore wear I eventually found. When I wrote this I was super worried about the angle of rotation of the injectors, which does matter, but nothing compared to any fuel leaks from head wear! If the fuel supply pressure to the injectors is low, then how can it function as it should? end EDIT.
The negative values are just the other cylinders being held back in injection to try and smooth the engine out, so those injectors are FINE, and the car is forever trying to make all injectors add up to a zero total ( apparently ). You can see in my odd second post purge result more -3.01 injectors trying to account for the extra +2.99 one. I realise the total now isn't zero, but again the ECU runs negative to try and get even idle, and my car sure shakes a lot. I'd not worry so much about "zero" and a lot more about any injector over +2 mg/stroke. Car still runs and not much changed power wise, but I figure a new injector in #1 and #4 should get the old girl back on her feet. This is something to watch via VCDS/Vag Com under engine measuring blocks, channel 14 being the 5th cylinder.
Tons and tons of posts online with all manner of conjecture, but basically a +2.99 is a maxed out injector, and it may not necessarily be the injector per say, so a compression test in any high reading positive cylinder would be a good idea, and despite my weird outcome, the fuel rail lines in a can of Liquimoly diesel purge plus ( or three cans like me, thankfully on special when I bought them ) can't hurt. Just beware the fuel sure heats up after a while, and the purge plus in my small container I had the fuel lines in was steaming by the time I got through two cans, so I stopped there!
For the record whilst pondering this problem, I decided to check / tweak the problem injector fitment angles, and did get all excited when I measured #1 being different to the rest. Tweaked them to all the same as the "good" ones, and sadly zero change. It did however show me the seal was fine, which on a higher mile engine is a concern, especially how the stock holders make the injectors wear on the other side and even supposedly creates a burr on the head port the injector sits in. I couldn't notice anything, but people have talked about it so it's something to take into account as a possibility. T10210 is the wedge tool. EDIT: I was looking in the wrong place, my head did indeed have these "burrs", I was thinking it happened down at the nozzle hole, not up at the top of the body / bore junction! See post 15 below!!!
If your loom / injector connection is the issue you won't get a constant reading under channel 12/13, was again a possibility I considered, that I hadn't plugged in #1 properly. Sadly wasn't that simple!
