Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 2.5 TDI AXE cam install TDC? HELP!
    Nov 2009
    2.5 TDI AXE cam install..Still Not Starting!
    Hi all - we are currently replacing a worn cam on our 2006 multivan (2.5 TDI AXE).
    Its going well, BUT the cam looks 180 degrees out.
    We are using the special tool (aftermarket kit from Germany) and Haynes manual for reference/torque values etc to set the crank and cam at TDC, however, when its all set up, the cam lobes on no.1 (i.e. driver's side) are pointing down. This has my father (a retired mechanic) confused as he is used to having the lobes point up and out (V shape). Makes sense as it closes both valves.
    I have little mechanical experience, but it also goes against what I can find on www.
    Apparently the tools can only fit in one way - which from our experience is seems to be the case.
    So what is going on here? Any help appreciated.
    Adelaide hills, SA
    I’m not sure if you’re aware or not? The Cyl. #1 is on the gearbox side.
    Nov 2009
    Thanks for quick reply Transporter.
    That makes a bit more sense lobe-wise.
    The Haynes manual states "1-2-4-5-3 (no 1 cylinder at right hand end of engine) - Assumed this to be from driver's seat. If you take it from the front of the car it would be gearbox side.
    Also, my dad is probably more family with normal petrol engines where No1 is at timing belt etc. Given that the AXE cam is gear driven then, the No1 is at cam drive end.
    Thanks again Transporter.
    Also out of interest, which oil (brand/type) would you recommend for the old girl?
    So much debate etc out there...Can't quite get my head around it.
    Dec 2008
    Sydney/Canberra
    506.01 is the correct spec for these, but it's impossible to find these days, and is horrendously expensive.
    504/507 spec 5W30 is ok to run in them. Brand wise, they're a much of a muchness. It's the specs that count.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    I’m guessing that your van production date is before 7/2006. in which case you must use 506.01 oil
    Liquid Moly Synthol 0W30 is the one to get.
    The 507.00 shouldn’t be used.
    See more here T5 FAQ and How to THREAD (up to August 2009).
    Nov 2009
    Thanks for feedback and link - can't believe I missed that one. Awesome resource.
    Van is Feb 2006 build (July 2006 compliance).
    Its a 2.5 AXE TDI SWB Manual 4motion (took a long time to find with these specs!).
    So oil - was initially looking at Fuchs Titan GT1 5W-30 which is 507 approved.
    But autobahn can get Liquid Moly 0W30 (special order ordered in @ $159/5L).
    I don't mind paying for the right oil (cheaper and less hassle than another cam etc).
    They can also get Penrite Enviro+ C2 0W-30 (@$55/5L) - so one third the price.
    (although not with DPF - which I'm pretty sure are only BXX engines? pls correct me if I'm wrong...). He did say that although Penrite recommend it for 506.1 it may not be quite as good as the Liquid Moly.
    Love the van but its a steep learning curve! I bought it at auction knowing it had the cam issue - it was audible and lobes were visibly worn when we took it out so knew we were in for a bit of work! Good way to get to know your van though!
    Adelaide hills, SA
    The Penrite 0W30 is not approved for your engine and the oil companies only guessing that the oil should protect that engine, but often they change their recommendation.
    I've had 2005 4Mo T5 with the same engine, so I remember a few occasions when the Penrite change their recommendations to "refer to the dealer" and not for just an engine application. There is also Fuchs Titan GT1 with VW506.01 though it's hard to get. The Autobarn price is inflated.
    Nov 2009
    Thanks Transporter - I'm sold on the Liquid Moly Synthol 0W-30. Its the right oil for the engine.
    Anyway, its $167.95/5L on their (Liquid Moly) website so figured that $159 at Autobahn was pretty much the going rate.
    Feel free to point me in a more affordable direction. Have to order it regardless of where it comes from.
    Adelaide hills, SA
    You pay premium price at Autobarn, unless it's on sale. I'd try Supercheap Auto.
    Imparts has Ravenol which is cheaper than Liqui Moly.
    More on engine oil for AXE here in this post.
    Nov 2009
    As an aside, VW here in Brisbane apparently use 504, 507 across the entire VW range.
