Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: 2.5 TDI AUTO TRANS thread
    Jan 2008
    Sunshine Coast
    T5 6 speed tiptronic AUTO TRANS thread Aisin O9K ( similar to O9G )
    Hi All,
    My 2009 BPC 174 engine is running like a train, seems it's sorted after the saga I've had getting there. See my pinned info thread if you are looking for engine specific info, or want to see the agony of repairing this unit from a zero knowledge base.
    My 6 speed tiptronic auto is the focus of this thread, as I'm finding on long trips it will flare, clunk and go into "all numbers" highlighted soft limp under certain conditions, and obviously needs a rebuild sooner rather than later. It is still driving fine, and on the recent 500km weekend trip only had three limp situations in heavy highway traffic, and a simple key off restart clears that.
    I've limited automatic gearbox experience beyond solenoids, so in the interests of losing the rest of my hair, and entertaining you all, I'm going to endeavour to first research, understand and then rebuild this notorious gearbox myself.
    What could go wrong?
    I've now done a few thou and will drop half the fluid - as much as will drain anyway, fit a new filter and gasket, and apply the "Mr Shift" USA O9G kit to the solenoids and drive like that for a few thou more. I've no doubt it probably needs a drum, pistons and frictions/metals, as well as a solenoid rebush in the least, but see how the fluid and shift kit goes.
    I'm installing a temp gauge on my external cooler so I can watch temps, and I think the fan that came with the external cooler should ideally be fitted, I have it off for clearance for now, and when it got hot on the big trip, it seemed to play up more.
    Let the messy ATF games begin ( hate that stuff most of all! )
    Greg.
    Feb 2008
    Adelaide,Oz
    Mine only cost $9K for a full rebuild , although it was in and out 3 or 4 times, doing partial fixes. Maybe would have been $6K-7K for a once off full rebuild.
    It was pretty much all good till about 160K km, then started clunking into drive. I had done my own (half)fluid and filter changes at 75K and 137K. Gearbox finally fixed at around 180K
    Trans rebuilder showed me the internals a few times and said basically the seals had gone hard causing probs. I found some rubber bits in the pan when i tried an oil change. I didn't run an external trans cooler, just the standard VW oil/coolant exchanger thing which lets the oil cook at a minimum of 90C(coolant temp).
    I run an external air/oil cooler now.
    I'll still be doing my own oil and filter changes every 50K or so.
    If you don't get any joy from your attempts, all i suggest is a full one-time rebuild. It won't get any better.
    BTW, here's my tale of woe
    The Torque Converter Auto (NOT DSG) T5 thumps into drive when cold
    Steve
    04 T5
    Nov 2007
    QLD
    My 2006 tiptronic started going erratic at about 280,000 km. After trying additives which seemed to help a little, the answer was simple, took it to Reliable Auto repairers at Albion Brisbane, and they said the problem is usually a worn valve body for one or more selectors and they can get it reconditioned by a man at Coomera QLD, then reinstalled cleaned and all other parts tested all for $2400. So I got it done and picked it up in about three days working perfectly. As it wore in, I needed to reset the gearbox computer a few times back to factory settings. Its now done 350,000 and still going good.
    T5 FAQ and How to THREAD (up to August 2009).
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by BrianJ View Post
    Great to know Brian, and handy for me in Caloundra too, thanks a lot for the intel.
    I'm going to try to rebuild it myself for the experience, and if that goes tits up, I'll be onto the Albion guy. I've already got some solenoid bushes on the way, and the solenoids are the same for the common 09G box. Seems our transporter 09K auto simply has different friction plates and metals to handle the bigger torx, but there may be other differences. The master gasket kit seems identical, even the pistons seem common. I'm buying an 09G rebuild manual tomorrow out of the states.
    Luckily it's not my daily nor needed for work, so if it's off the road for several weeks only my missus will get upset we aren't doing weekenders. The big upside is how good the engine is now, and given the low kms I will really put on this once a month camper, should see it out for quite some time.
    Jan 2008
    Sunshine Coast
    I'm going to do the stub axles and driveshafts while in there, have read just doing stubs is risky given they wear as a set.
    Interested to know if anyone can tell me about these "stronger" revised stubs VW have, given they seem to be the weak point.
    I will probably just go generic shafts given my low use of the van, hate to think what genuine costs.
    Feb 2008
    Adelaide,Oz
    I think the revised gearbox stubs for the driveshafts are just longer for more engagement, so they don't strip or wear splines out so much. Haven't done them myself.
    Steve
    04 T5
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by Rebuild View Post
    Thanks Steve, makes sense, not much else they could do apart from alloy / heat treatment.
    Jan 2008
    Sunshine Coast
    OK, I'm into my trans this arvo, and am currently fighting the good fight to try and get the valve body out without having to raise the engine off the lower subframe - of course the valve body *almost* drops straight out, and if someone with some foresight had allowed about 2cm of clearance in this area it would, but of course the T5 factor comes into play.
    First thing I noticed was one of the two looms has gone hard, and a lot of the wiring insulation has visible cracks and gaps. Has done the typical wiring in hot oil thing, just like the old PD injector loom that used to fail and became part of that PD injector recall in the MK5 era. Anyway the common O9G loom is identical to our 09K looms, and rather than pay the $300-$500 for an OEM one, there's tons out of China for about $50, but with the usual few weeks delay. I found the temp sensor / input and output sensor loom is fine, and the insulation and plugs seem pliable as normal, perhaps it's been replaced already. It's the solenoid loom that two of the blue plugs snapped in my hands, and the insulation is rock hard on, so that has to be replaced for sure.
    Once I get the valve body out I'm going to do the shift kit, reinstall the interim patched up loom and see how it drives. I found a great video outlining a few things to watch out for, and of immense interest, mentions the adjustments on the other end of the main solenoids to change shifts and gear changeover ( flaring?? )!! Going to take note in where my problems actually are in the various gears, and try some adjustments once the China loom arrives and I have this thing back off for the install.
    Another interesting thing this video alerted me to is the fact that the auto shown has separate diff oil to the trans oil, but looking at mine there is a blank plug where the video shows a drain bolt, so perhaps this was an earlier T5, and my mid 2009 T5 diff is indeed sealed for life. Will investigate.
    I'm sticking with my initial Titan 4400 trans oil, but I'm sure any approved oil will be fine so long as you don't mix if you can help it between changes. I'm also putting in the Lucas stop slip stuff, as for $30 how can it hurt and I've read good things about it several times. This will then be my second half fill of the box, and what came out looked just fine, but it's only done a few thou, and this is really a second flush as much as anything, and a swap of filter too, only because they are cheap and I had a Ryco kit on hand.
    Aussie valve body info video - 09G / 09K / TF60SN Valve Body Removal and Replace - YouTube
    Late T5 auto temp / input and output sensor loom:
    2.5 TDI AUTO TRANS thread-a15446a-jpg
    Late model 14 pin Solenoid loom which is hard and buggered in mine:
    2.5 TDI AUTO TRANS thread-09g927363-09g-927-363-oem-vw-audi-skoda-09g-6-speed-auto-transmission-jpg
    Jan 2008
    Sunshine Coast
    For future reference there are different looms that changed around 2005 for our vans. This info is from Alibaba, and is O9G specific, so best do some extra research if you find a loom problem like me for our O9K. Here are all the O9G looms I found in China for reference.
    2.5 TDI AUTO TRANS thread-htb1izabxsnrk1rjsspkq6yuvxxau-jpg
    2.5 TDI AUTO TRANS thread-htb1j_kbxtfvk1rjsszhq6acgfxao-jpg
    2.5 TDI AUTO TRANS thread-untitled-jpg
    2.5 TDI AUTO TRANS thread-untitled2-jpg
    Jan 2008
    Sunshine Coast
    Can confirm valve body comes out without having to raise the engine off the subframe, but boy is it a Tetris puzzle till you work it out.
    Undo the very outside bolts down each side, noting the short vs long ones. Strip the body of all the looms etc, be very careful withthe plugs and take some pics of where it all goes, it's real easy to mess up the plugs for the N92 / N282 solenoids, all the rest are keyed. Wriggle it down at the N90 front of van end and remove the accumulator piston and spring, see pic #1. Next, work on getting the passenger / non main solenoid side up as high as you can with the N93 area as low as possible at the left back of the valve body ( Pic #2 ). You can wriggle the N90 upper edge out with a bit of work, there is even a milled small cut out for the top 10mm bolt that hits the gearbox housing itself, but with some careful wriggling it comes out just fine ( Pic 3 onwards ). Goes back in the same way. Tricky, tight, but entirely possible.
    1. After getting all the junk off, drop the front edge and get the accumulator piston and spring out ( arrowed ).
    2.5 TDI AUTO TRANS thread-pxl_20230606_055532036-jpg
    2. Next get the drivers rear side as low as possible, with front and passenger side high. Takes some work, so be patient.
    2.5 TDI AUTO TRANS thread-2-jpg
    3. Here is the top 10mm bolt and the cut out that helps it come out, it's bloody tight, and you need to man up and wriggle it.
    2.5 TDI AUTO TRANS thread-3-jpg
    From there it pretty much falls out.
    2.5 TDI AUTO TRANS thread-4-jpg
    2.5 TDI AUTO TRANS thread-5-jpg
