Results 1 to 6 of 6
Thread: 2.5 T5 Manual 170000kms what fluids should I change and links to how please.
    Jan 2015
    Chapman ACT
    Hi Guys.
    Had my T5 for close to a year, changed the oil and filter twice now, but what else should I be changing, checking? Oh I changed the coolant too.
    Is there a diesel filter? or drain?
    Gearbox, transfer oil change when?
    Anything else important?
    Please send how to links. I am competent, just not that T5 knowledgeable.
    Thanks in advance.
    Jan 2015
    Chapman ACT
    Can anybody help?
    Mt Cotton
    Do you still have your service schedule booklet it will give you the items that should be changed at each interval . If not I can look them up for you .
    Dec 2008
    Sydney/Canberra
    Major service is due at 180,000km.
    Engine oil and filter
    Fuel filter
    Air filter
    Pollen filter
    Auto trans oil and filter (if auto)
    Haldex coupling oil (if 4Motion)
    Manual transmission, bevel box (4Mo), and rear diff (4Mo) are supposedly filled for life, so change as you see fit.
    I think the Gates couplings on the air con compressor and alternator are due at 180,000kms as well.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2015
    Chapman ACT
    Cheers guys.
    Is there a water drain on the diesel filter?
    Gearbox is feeling a bit less flowy to change, is it oil change or do they get loose couplings?
    Dec 2008
    Sydney/Canberra
    Try changing the oil in the gearbox, and see how that goes.
    No water drain on the filter. If you suspect water ingress, replace the filter. They're about $90.
    '01 Beetle 2.0
