2.5 Petrol Distributor Part
Hi Everybody,
Wondering if anybody would know where I could get the round plastic disc at the base of the Distributor, removing the Dizzy from the engine it sits over the the shaft and about 50mm in diamater and 6mm thick with a roll pin through the centre, mine has a hairline crack but don't really want to throw away the whole unit!
Any help would be greatly appreciated.
which 2.5 engine T4 ? there are some variations . I do have a 2.5 petrol engine complete with gear box etc it has the dizzy complete still bolted in place . The part I presume can only be seen with the dizzy removed is this the case ? If the part has a number post it and I,ll see if this ones the same Howard
Hi,
I don't have a number off the dizzy but the vehicle type is a 7DH and the engine number starts with AET00 if that is any help.
Thank you
Nigel
---------- Post added at 10:37 AM ---------- Previous post was at 08:55 AM ----------
Additional to above, I have found a diagram and the part number: it is called a driver No:030905242.
Distributor. Fits: Volkswagen (VW) | Jim Ellis VW Parts
- You may not post replies
- You may not edit your posts
Forum Rules
