Results 1 to 10 of 13
Thread: 13.6v when running
    Feb 2009
    NSW
    13.6v when running
    I have a 2011 4motion tdi132. It only puts out 13.6v Max when driving. Is this normal? I thought they were supposed to be 14 +ish volts?
    Sent from my Pixel 2 using Tapatalk
    Sunshine Coast
    13.6v is totally normal mate 13.6v when running
    Sent from my SM-N960F using Tapatalk
    Feb 2009
    NSW
    If that's the case, why does it seem hard to start sometimes?
    Mt Cotton
    Even if yours was putting out 14v that would not help its the crank amperage that counts , I would suggest to get the battery load tested it will tell you if its getting weak .
    Feb 2009
    NSW
    Bloody hell... It's a new battery!!
    Mt Cotton
    Okay then it needs further checking for some other issue , does it turn over slower or just hard to fire up . Could be just the colder weather I know ours seems slower at the moment to fire up but like yours the battery is fine . What is strange is my petrol T5 starts normally but the wifes T5.1 diesel is slow to start .
    May 2019
    My 2011 132 puts out 14.2+ volts with engine running. Having the heated seats and heated mirrors on can increase demand on the alternator and reduce system voltage.
    Checking the health of your alternator and battery would be good for peace of mind.
    Feb 2009
    NSW
    It does both sometimes. Others is fine. We had an issue a while back which was a cracked head leaking coolant I to the cylinder, so it was trying to crank with fluid in there. Might need to check the alternator..
    Mt Cotton
    Also check the main battery cables as they can get corrosion between connections especially the earth ones , I found on my sons T4 many years ago the earth cable going to the engine block from the body was dodgy , after a clean up no more problems .
    Erskineville, NSW
    Our Honda was cranking slow. The ridiculously small battery died and we thought that was the issue. 3 months later it started again. Eventually the starter motor gave up.
    Why don't you get a sparky to check your system. It should only take 30mins max.
    Alternator output
    Battery load test
    current draw
    voltage drop between components
    resistance in the wires
