Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 13.6v when running
    Jun 2012
    NSW
    If the voltmeter used is reading correctly, 13.6v is too low to keep a 12V battery fully charged,
    you might have to check it with a known accurate voltmeter, 14.2V to 14.4V is the usual voltage
    on the non smart alternator. If the battery has been discharged lately it might take quite some
    charging to bring it to ~14.3V.
    Feb 2009
    NSW
    Drive from musswelbrook to Sydney and still 13.6. Peaked 13.7
    Sent from my Pixel 2 using Tapatalk
    May 2013
    Not far from Cooma
    Your battery stores the cranking power to start your vehicle. Your alternator provides charge to keep the battery charged. The regulator (usually built into the alternator these days) prevents the alternator from over charging the battery and I believe it also determines what voltage shows when the engine is running.
