There is, just not sure which pin-out.
Hi,
Does anyone know if there is a IGN point under the drivers seat that can be tapped into?
Under the drivers seat I have installed a redarc BCDC1225 (DC TO DC CHARGER) and would like to also connect solar panels to the system which requires a changeover solenoid to be installed that is triggered by the IGN.
Thanks
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Test meter would probably give you an answer don't use a test light as it may cause a short .
