Results 1 to 10 of 12
Thread: 12v power source
    Jul 2014
    Hervey Bay Qld
    12v power source
    Hi,
    I am looking for a 12v power wire around the radio or fuse box area that I can splice into that switches off with the ignition which I can use to power a wireless reversing camera screen on my 2012 Transporter
    I want to hardwire it in and not use the cig lighter socket.
    Have tried tapping into the radio power wire but it won't switch off with the ignition and drains the battery
    Thanx
    Adelaide hills, SA
    You could use the Narva Add a circuit. Did you look in the sticky thread for which fuse to tap into?
    Jul 2014
    Hervey Bay Qld
    Thanx for your reply Transporter
    Yes I did look at the sticky thread but I wouldn't have a clue which fuse to tap into.
    Adelaide hills, SA
    You could use the cigarette lighter socket fuse no.12 as in this post T5 FAQ and How to THREAD (up to August 2009).
    Just check first if there is 0V when you remove the key from ignition.
    Mt Cotton
    Best method is to use a test meter and touch each fuse with ignition on and then turn off to find one that goes out at the same time , then as was posted use an Add a Fuse I have hundreds of them I use for work and import them directly from China those Narva ones are ridiculously overpriced. Okay here you go this where we plugged our camera into last one on middle row of bottom batch of fuses right next to screw holding fuse block in place
    12v power source-20141210_181531-jpg
    Jul 2014
    Hervey Bay Qld
    I wish it were that simple, the cigarette lighter socket is permenantly on (12v) even with the ign key removed
    Same with the power wires going to the radio are permenantly on (12v)
    even tho the radio switches itself off after 30min with key removed.
    EDIT just saw your last post Thanx Sunny43.5 I'll do that
    Mt Cotton
    Sorry about that I was trying to find a cable to connect mobile phone to PC [mine's on it's way to the US with my son ] any way glad to help if you need an "add a fuse" let me know I can shoot a couple up to Hervey Bay for you .
    Oakleigh VIC
    Isn't there a Terminal 15 interface under the passenger seat?
    https://www.dropbox.com/s/4e7ue3fe9b...rface.pdf?dl=0
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Pacific Paradise QLD
    ANother way of doing it is as I have done for my dashcams.
    I have used a spare fuse socket in the fusebox and put a fuse in with a wire already soldered to it (Hard to do yourself)
    I just metered each one and turned the key off each time Several were only on with the ignition so I just used one of them. Also needed an Always on so got one no trouble.
    This is the fuse I used Get it from Jaycar comes in standard and mini sizes $6.95 each Work like a charm Put it in with the wire on the blank size so it will still work as a fuse. If its the other way it wont as poower will be direct to the pin.
    Jul 2014
    Hervey Bay Qld
    Awesome, thanx heaps for the replies, very helpful
    and to Sunny43.5 for your kind offer, but I'll pick a couple up from Jaycar save you the hassle
