Pull the rubber convoluted tube back inside the door jamb, where the hinges are, and check for broken wires.
ok so i disconnected the battery the other day and now the passenger door has no power no window no lock no mirror movement . what could be the problem .. starting to think maybe this car has been under water in the vic floods
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Thanks I've checked that but no problems I can see
There may have been some water ingress at the power window switch or the motor/control module. This is also quite common on the Caddy.
While you may not see actual liquid if you look inside the connectors, you may see a light blue film of corrosion.
'01 Beetle 2.0
