Results 1 to 3 of 3
Thread: Who has a recent Caddy and VCDS?
    Aug 2009
    Melbourne, Vic
    ABS module coding help
    I am trying to map out the "long coding" of the newer MK60EC1 ABS module as fitted to various recent VWs. This info has not been published yet. To do this I am grabbing the ABS long coding from different types and comparing the differences. I Don't have one from a Caddy or Polo yet. Any chance someone here has a recent CADDY and VCDS and a spare 5 minutes? If so could you PLS grab me a Full Scan. Either PM it to me or post it in a reply would be great. I dont need you VIN number so erase if you have any concerns. But the rest of the full scan would be good as it helps me to cross reference stuff. Thnx.
    Scan from May 2010 caddy Maxi Life
    Hi,
    Hope this helps.
    A recent scan from my May 2010 Caddy Maxi Life,
    Seems to be a dodgy rear park sensor!
    Mike.
    Monday,23,August,2010,10:22:30:17284
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 46 52 56
    VIN: mix_vw_caddy Mileage: 610km/379miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 021 PH HW: 03G 906 021 AB
    Component: R4 1,9L EDC G000AG 2389
    Revision: --H11--- Serial number: VWX7Z0J13N910C
    Coding: 0000078
    Shop #: WSC 35110 377 00169
    VCID: 74C90EE86ED0
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 053 D HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2103
    Revision: 51112 Serial number: 00001002051193
    Coding: 0000020
    Shop #: WSC 35110 666 38454
    VCID: 160D146058EC
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 2K3 907 379 HW: 2K3 907 379
    Component: ESP FRONT MK60 0101
    Revision: 00H13001
    Coding: 0021202
    Shop #: WSC 35110 377 00154
    VCID: F3CB8DF4EBDE
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 JN HW: 1K0 820 047 JN
    Component: Climatic PQ35 143 1515
    Revision: 00143034 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 79D73FDC49B2
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 01000003704163
    Coding: E1884F030004100057000000000000000008FF075C00012000 0000000000
    Shop #: WSC 35110 377 08192
    VCID: 334BCDF42B5E
    Part No: 1T2 955 119
    Component: Wischer 160210 021 0512
    Coding: 00038805
    Shop #: WSC 35110
    Part No: 1K0 955 559 AH
    Component: RLS 180210 054 0403
    Coding: 00209133
    Shop #: WSC 35110
    Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
    Part No SW: 1K0 919 475 K HW: 1K0 919 475 K
    Component: PARKHILFE 005 1706
    Revision: 00005000 Serial number: 0 263 004 388
    Coding: 100101
    VCID: 3A55E0D00C34
    1 Fault Found:
    01545 - Sensor for Parking Aid; Rear Left (G203)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 17 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:54:09
    Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
    Part No SW: 6Q0 909 605 AJ HW: 6Q0 909 605 AJ
    Component: Z6 AIRBAG VW52 025 2400
    Revision: 06025000 Serial number: 0037UR03G437
    Coding: 0023094
    VCID: 7F23D1C45796
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CM HW: 1K0 953 549 CM
    Component: J0527 053 0111
    Coding: 0001034
    VCID: 7F23D1C45796
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1T0 920 864 A HW: 1T0 920 864 A
    Component: KOMBIINSTRUMENT VDD 1212
    Revision: V0002000 Serial number: VWX7Z0J13N910C
    Coding: 0018101
    Shop #: WSC 03002 959 06940
    VCID: 334BCDF42B5E
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0112
    Revision: H07 01 Serial number: 160210F1001940
    Coding: ADA01F06000202007401
    VCID: 69F76F9C3912
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 1212
    VCID: 334BCDF42B5E
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
    Component: Tuer-SG 009 2110
    Coding: 0000560
    VCID: 48B18A1842D8
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 CP
    Component: KSG 0401
    Coding: 008B04087F2D8405485A030000C0
    VCID: 8021D238AA68
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0000560
    VCID: 47B389244FC6
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
    Component: Radio RCD310 016 0049
    Revision: 01000000 Serial number: VWZ1Z2K8045231
    Coding: 0500040002
    VCID: 65EF63ACD50A
    End ---------------------------------------------------------------------
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by mix_vw_caddy View Post
    Hi,
    Hope this helps.
    Coding: 100101
    VCID: 3A55E0D00C34
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 45
    Mileage: 17 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:54:09
    Thanks for that. Seems the Caddy does not actually have the MK60EC1 ABS controller I was looking. So seems I was barking up the wrong tree. Thanks anyway.
    Don't worry too much about that sensor fault. Seems it has only happened twice, the last time when the car had 17km on it and it will self clear after 45 fault free cycles. If I read correctly it has been fault free for near 600 km so chances are it was a transient that will self clear.
