If you check the sides of the boot/rear you should be able to find the internal release cable, on my Golf it is hidden behind the boot trim, but there is a cut in the carpet so you can access it. It has a big yellow tag. All modern cars are required to have one, it's part of ADR's I believe, be very suprised if your car doesn't have one!
