you will see the light
Accessing the rear lights for a bulb change on The Caddy is a bit of puzzle when you first look at it.
With the rear doors open fully you need to pry the plastic insert that is at the side of the light away carefully.
Once you have done this the phillips head screws will be revealed.
Undo these little chaps and you will be able to remove the tail light and change your globe.
Took me a little while the first time.
But you must do it in order to get the bulb warning light to go off on the dash.
Hope this helps
Pete Mk1
Golf mk1
Passat 4 Motion
Polo GTI
Caddy TDI
