Rear tail light upgrade
Im After some help with wiring config to upgrade rear tail llight to k4 type. I had done this upgrade in the past 2014 but have completely forgotten wiring configuration
Ive checked and only caddy2k forum might have answer but cannot view thred. If anybody could help would be appreciated
Here is the info nice and easy for anyone wanting to do it. Info is free like it should be, no need to search endlessly for no answers and whoever has answer not willing to share
This is left side for new tail light wiring
Right side requires new pin to be added at terminal 5 for fog light.
I used a old wiring harness to obtain right size fitting, drilled through empty hole location with small drill bit in the new carrier, fitted and soldered new pin to board. You could find another way to make the connection its up to installer
No coding needed plug and play
Forgot to take picture of right
Here are new terminal pinouts
Yellow/white rear fog to pin 5
Grey/red rear tail light to pin 4
Green/black rear right turn signal to pin 3
Blue/black to pin 6
Red/black right brake light to pin 2
Earth pin 1
- You may not post replies
- You may not edit your posts
Forum Rules
