the large fan houses the radiator fan control module. It could be cactus.
Hi everyone . Hope someone can help , the radiator fan on my 2006 VW Caddy TDI does not come on causing the A/C to turn off and the car to overheat in traffic . I have checked all the fuses, I have power supply to the main plug to the fans but cant find any info on the activation of the fans ie relays or control modules . If anyone has any experience with this your input would be appreciated . Unrelated I also have a knocking noise/vibration through the steering wheel at around 100 KPH , it goes away under accelleration and decelleration , I thought possible driveshafts? Anyone? Thank BRB
yes the the large fan is the problem..it has got built in control module...the retail around 400+
I have one for sale secondhand, so if you need it let me know
cheers
Oli
Thanks all sorted , found a second hand 1 at work . Same as Audi A3 and TT.
