Results 1 to 10 of 10
Thread: oil filters
    oil filters
    seems the 1.9tdi have a couple of different oil filters
    top one is the one supposed to fit according to the dealer
    the bottom one is one out of the vehicle..
    bugger :p
    oil filter housing
    2010 Caddy 1.9L DSG
    Ross-Tech Micro-CAN
    Visit my Caddy links Page
    Point Cook, Vic
    are they both genuine or is one after market brand?
    FOLLOW US ON FACEBOOK
    both genuine
    2010 Caddy 1.9L DSG
    Ross-Tech Micro-CAN
    Point Cook, Vic
    I guess if you are in doubt you could always look up the part numbers and see which engine codes they are suited to. They dont look to be the same size though which is strange.
    they arent, one is longer and has the long plastic plug
    will be ringing them monday ...
    2010 Caddy 1.9L DSG
    Ross-Tech Micro-CAN
    Point Cook, Vic
    what are the part numbers? It should be stamped on them.
    Adelaide hills, SA
    You broken it, when you were removing it, they're the same filters. You have to pull the broken bit out of the oil housing now.
    The new one is Purflex and old one is Mahle (the same).
    thanks for the tip...
    you had me there for a moment as it had me stuffed how i could have broken anything as i was pretty careful.
    seems two brands of filter and two different methods of manufacture / assembly.
    the original filter is actually in two bits clipped together and the clips on the nozzle were weak enough that they wouldn't hold when lifting the filter body out..
    new filter looks one piece or is glued and that doesnt look like it can occur..
    2010 Caddy 1.9L DSG
    Ross-Tech Micro-CAN
    Adelaide hills, SA
    Yep, Mahle is the one that you didn't pull out in 1 piece. The Purflex - the new one in you picture is one piece cartridge.
    Did it come out easy?
    not really... long nose pliers sorted it....
    thanks for the assist.
    2010 Caddy 1.9L DSG
    Ross-Tech Micro-CAN
