Page 11 of 39 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 383
Thread: My Caddy Van
  1. #101
    Chipped diesels rock big style
  2. #102
    wheres the pics at bro!
  3. #103
    Jun 2006
    Orange NSW
    Ok, finished the caddy off today.. (And then washed it..)
    Pretty straight forward swap for the rear, just did one side at a time and used the wallaby jack to support the axle.
    Here's some pics..
    Here's the setup. Simply puts the axle ohttp://www.vwwatercooled.org.au/newforum/upload/newreply.php?do=newreply&noquote=1&p=187017n top of the springs and then you put another rear shackle set on that has 4 sets of holes for height adjustment.
    Dropped off the hoist..
    And here it is after being washed, at home.
    Back at the workshop.
    Official tuff sticker..
    And here it is after i decided that i was going to lift the back up one hole (10mm) from lowest..
    Dad made me do it! Although i think he is right. Give it a little more rake. Plus the mudflaps were scraping going out of the driveway most places. (Still does, but not as bad.. )
    Now for a suspension analysis.
    Ride
    It's pretty freaking good. Just a little firmer than standard on the bumps, but sooo much better. The car doesn't wobble around at all like it did a bit standard.
    Handling
    Fantastic. Initial turn in is light years better. You point the wheel and immediately it goes there. Previously, on entry, the car would tip too much weight onto the loaded front tyre, causing it to tuck under (due to it being a 195/65 tyre).With the new suspension, the car rolls onto the front just enough to give the outside front some bite, and it holds on.
    Midcorner the car is very well balanced, with just a touch of understeer if too much throttle is applied.
    Once you're in the corner, the car's midpoint can quite easily be adjusted by the amount of throttle input. Lift off and the nose tucks in and lets you still know the back is there, apply some more throttle and the front will creep off the apex a little. Very settled, plenty of feel (Vast improvement) and very easy to drive.
    Corner exit has been vastly improved. Previously (if you tried to get hard on the throttle) the car would get massive power understeer and the inside front would start to let go quite badly before the traction control cut in and dropped the power output to control it. Now, the car doesn't transfer the weight of the front on throttle, so you can get on it agressively if you wish, and hard.
    The car is almost neutral on the exit now. You can actually get a little bit of oversteer (very controllable) given the right corner characteristics.
    So, all in all...
    It was TOTALLY WORTH IT!
    I'm very happy with this suspension and would definately recommend this kit to anyone.
  4. #104
    awesome bro........
    NOW CHIP IT and get some new wheels!!!!
    get rid of those freakin mud flaps would you? next youll have an RM Williams sticker on the back LOL
  5. #105
    Jun 2006
    Orange NSW
    Quote Originally Posted by GoLfMan View Post
    Thems fightin words! I very much dislike those type of cowboy idiots.
    For 150 bucks i'll be (Derfinately) getting a piggyback chip. I'll be able to hose off some serious excels then!
  6. #106
    ooh dont we all have those utes......
    as for those piggyback chip i too have invested in one for the Polo Tdi
  7. #107
    Jun 2006
    Orange NSW
    Wha? have you got a polo TDI?
  8. #108
    Feb 2007
    Bunyip, Victoria
    awesome bro........
    Whats wrong with mudflaps?
  9. #109
    Jun 2006
    Orange NSW
    Quote Originally Posted by ScienceVR6 View Post
    Those aren't quite as rigid as mine. I'm thinking i might pull them off ans see how it looks. They're scraping on heaps of stuff.
  10. #110
    Do you get a lot of lightning strikes where you live the fronts are earthed LOL
