Page 9 of 39 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 383
Thread: My Caddy Van
  1. #81
    I don't want poverty pack stuff. I'd rather pay the extra.
    I wouldn't be too quick to rule out cheaper alternatives. When I bought coils (weitec) they were just a company (also made by KW) that I'd heard good things about. Because you want damper adjust etc I'd say you would be in the minority. Having driven Weitec next to hottuning the difference is zero.
    Those KW's look the dogs I'll say that. When are you fitting these coils I can't wait to see how you go
  2. #82
    Jun 2006
    Orange NSW
    Quote Originally Posted by evorobin View Post
    I didn't mean I only use "brand name" stuff or expensive stuff, I just mean I don't like buying crap.
    Those hottuning coilovers seem pretty good even though the name screams supercheapauto type stuff. (not that all super cheap stuff is bad but you know what i mean).
    Fitting them this saturday. Can't wait.
  3. #83
    Jun 2006
    Orange NSW
    Heh, a few of the guys that have come into the workshop were like "Oh, you've got some new suspension for the golf.."
    So i say "Nah, it's for the caddy, i'm lowering it."
    And they said "Nah piss off stop having me on."
    And I say "No, i'm serious... Seriously"
    And they look at the old man and they're like "Is he serious or what? He's kidding right?"
    Dad's like, "No, they're for the caddy..."
    And then they're impressed.
  4. #84
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
  5. #85
    Jun 2006
    Orange NSW
    Quote Originally Posted by 99gti View Post
    Ok well here it is AGAIN then.
    And here's whats going in it!
  6. #86
    Jun 2006
    Orange NSW
    Started on the caddy tonight. Got the fronts done.
    FYI: Before you start jerking around, drop the control arms off on the inner side. 4 bolts and it saves a lot of jerking around when you get the strut all but 10mm out and figure out that it won't go any further.
    Fairly straight forward swap. Obviously we did it on the hoist so there was no crawling around on the ground, but I don't think it would be THAT much harder if you were doing it with jacks and stands.
    First up we had to remove the scuttle panel to get to the top strut bolts.
    Then to get the strut out, you need to put a lever into the slot where the front upright claps around the strut. Lever the slot open to give enough clearance to slide the strut up and out of the upright. You may need a rubber mallet to whack it up and help it move. (Two man job. )
    You need to get the strut bearing assembly off the old shocks to use on the new ones, so once you've done that, you can reassemble the new struts with the original bearing.
    I set the perch at 10mm off bottom (10mm off lowest) to start with.
  7. #87
    Jun 2006
    Orange NSW
    Then its time to put the new strut back in. The new struts are a heap shorter, so there's no jerking around to get them back in. Lever the slot open and the strut slides straight in. Easy..
    It's basically just the reverse of how you disassembled it.
    Then you just have to do the other side the same.
    Once the other side is done, you can THEN re attach the control arms and the sway bars.
    Then you can drop it down and realise that the hoist is stuck under the car!
    So we had to put some blocks down under the front wheels, wind the hoist pads down and then lower the car down..
    And here's a shot outside the workshop. Pretty crappy, my phone's camera isn't much good in that low light.
    More info and pics tomorrow after i've done the rear. Oh, and a review on the handling/ride quality.
  8. #88
    Jun 2007
    Eastern Suburbs Melbourne
    hahahaha that's awesum!
    needs to be lower though! hahaha
    i like volkswagens
  9. #89
    Jun 2006
    Orange NSW
    Dad reckons it needs to be 10mm higher in the front to centre the wheel in the guard.
    I said we'll do that back and then decide..
  10. #90
    I like the way you work Preen. Next on the agenda is bumper colour coding!
